S15 - The Old 57Ing , Now With R33 5 Speed And Forged Engine Rebuild
2002 Nissan 200SX Spec R S15
Engine Mods
SR20DET - REBUILT WITH FORGED INTERNALS BY GAVIN WOOD (RECEIVED CAR BACK 19/07/2012) $6500 OF WORK.
Apexi Power FC + Apexi hand controller
Garret 2871R .64 rear housing, 56 trim
Stainless GKTech exhaust manifold
AM Performance screamer pipe
Tomei Cams 256/260
Tomei Cam gear, exhaust side only
GKTech Rocker Arm Stoppers
Nismo 740cc Injectors
Z32 AFM
Apexi Power Intake Pod Filter
Drift Oil Catch Can
Hi Octane racing hot air diversion plate
Front Mount Intercooler
Aftermarket big thick radiator
Just Jap Racing 19 Row oil cooler relocation kit
Blitz Blow off Valve
Apexi AVCR boost controller
Walbro intank fuel pump
3-inch stainless steel exhaust system to a HKS cannon muffler
Nismo Oil cap
Apexi Radiator cap
Driveline & Brakes
NOW WITH POWERTUNE R33 5 SPEED CONVERSION
C’s 5-speed short shifter kit
NPC Heavy Duty clutch
NPC lightened flywheel
DBA slotted rotors, front and rear
Bendix Ultimates
Suspension
Tein adjustable coilovers with adjustable pillow mounts ,( RAISED TO STAY LEGAL)
Fulcrum pineapple rings
Cusco front strut brace
Just Jap Racing engine dampener
Wheels
Work Meisters S1 3-Piece
18 X 8.5 +24
18 X 9.5 +30 (BRAND NEW REAR TYRES)
Exterior
STANDARD FRONT BAR PUT BACK ON FOR GROUND CLEARANCE
Nismo side and rear skirts
Interior
Apexi EL mechanical boost guage, mounted on A-piller, reads up to 2 Bar
Apexi turbo timer
Nismo gear knob
Pioneer MP3/IPOD head unit
Power
250rwkw's (335HP at the wheels) - OLD FIGURE IS CURRENTLY BEING RUN IN AND WILL BE RETUNED BY GAVIN WOOD IN 2000KMS
  • 1 year later...
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
