I've decided to finally end the build of my R33 Skyline.
I've had a rough journey with it thus far, and with other priorities standing in my way this needs to be done.
Everything will be stripped from the R33, once most items are removed or sold I will then advertise the car as a rolling shell (open to offers).
1. RB25 alternator
Perfect working order
$60
2. RB25 power steering pump
$60
3. RB25 S1 splitfire coil packs
$400
4. RB25 ignition module
$50
5. RB25 spark plug cover
Great condition
$50
6. RB25 gearbox (14X,XXXkms)
No crunches, nasty sounds. Very smooth
Has a Nismo heavy duty clutch pivot too.
$1100
7. RB25 starter motor
$100
8. Nismo engine mounts
Essentially brand new
$200
9. OMP style seat and super dooper low fixed seat rail
Custom to suit my seating postion, I’m 6’2 and 95kg.
$400
10. Sabelt steering wheel
Near new
$200
11. Racetech 60mm oil temp water temp oil pressure & boost
Near new includes senders
$70 each or $250 for the set
12. S14 Buddyclub racing spec coilovers
Appear to be in good condition, no leaks.
8/6 spring rates
$700
13. URAS type 4 bodykit
Near new, rattlecanned bayside blue
$350
14. JDL roof spoiler
$130
15. 2 Litre surge tank setup (includes bosch 044)
All near new
$350
16. Wire tucked engine loom
Done by Dahtone Racing, the loom is completely hiden in the engine bay, re-routes the fusebox to the interior and tucks part of the loom above the drivers side wheel arch.
$500
17. shortened piping intercooler kit
Designed to be used with a forward facing plenum and a high mount turbo
includes core
$500
18. Panasonic thermos
$100
19. Re-located Power steering bottle
$100
20. Nismo indicators
$50
21. Nismo 2 way LSD complete in housing
Roughly 20,00kms old, brand new nismo/motul oil
$1100
22. Nissan S15 throttle cable
Perfect for forward facing plenums
$100
23. S14 Driftworks offset rack spacers
brand new
cut a tab to fit R33, was sent wrong item.
$150
I will add more items when I come across them (forgotten some).
Located in liverpool region, NSW.
Will ship at buyers expense.
Open to offers on most items.
SMS me on 0410-65-one nine eight nine for more info
I will get pictures up in a couple of days.
Adam.
Edited by Run-It-Hard
  • Replies 51
SOLD
SOLD
SOLD
Re-posting due to images and not being able to edit original post (how convinient!)
1. RB25 alternator
$60
$60
$400
$50
Great condition
$50
$1100
$100
SOLD
SOLD
Near new
SOLD
12. S14 Buddyclub Racing spec coilovers
8/6 spring rates
$700
Near new, rattlecanned bayside blue. Includes R34 front indicators
$350
SOLD
All near new
$350
$500
includes hybrid intercooler core
$500
$60 each or $100 for the pair
$100
20. Nismo side clear indicators
$50
$1100
$100
brand new
$150
24. S14 inner tie rods
Brand new in packaging!
$50
25. Stagea C34 S1 Bendix CT brake pads
front and rear, brand new!
$130
26. Kuhmo KU36 275/35/18 tyres
Roughly 30% tread, good for burning up, or running for a month or so.
$120 for the pair
27. 3 Inch resonator
Brand new
$60
28. RB25 OEM throttle body
$50
29. Safety21/Cusco 6 point rollcage
It'll fit both ECR33 and BNR33 models.
It's a great cage, very unobtrusive, doesn't get in the way etc.
$900
30. Series 2 rear spoiler
$50
Hey Adam,
Cant tell from the pic, but if those guages are blue then send me a PM, if they are white then nevermind :) Chasing blue ones and too lazy to order them through ebay lol
Hey mate, have you got any front bamber arms or toerods for sale?
No I dont, sorry.
Hey Adam,
They are white, forgot to mention that.
S14 is the same length as an R33 throttle cable, I found out the hard way. I believe the S15 cable is roughly 30-40mm longer (will need to measure them to be exact).
ONLY water temp gauge left!
Gauge holder
SOLD!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
