Hi
Just would like some tips on a few stuff.
1) Say i have buy ethanol content sensor, would it be possible to get a tune done for a nistune so i have 98 tune, e70, e75 and e80 maps loaded on, then when i fill up, i can check the ethanol content on the reader and then plug a laptop in and load the correct map via the consult cable ? How much would this involve in dollars usually, i would assume that would be considered four seperate tunes.
2) If i purchase a wideband sensor + gauge + controller say from innovatemotorsport, would i be able to replace the wideband with my narrowband ? Would the controller be able to be plugged into the stock wiring for narrowband, and then be able to use the wideband for tuning, or do i weld in both sensors ? and would it be compatible with nistune, or do you monitor that seperately?
3) Would it be worth upgrading engine mounts when going from stock to 300rwkw+ especially that the intake manifold and turbo are both out, is the job not too hard for the side mounts ? Any diagrams or guides ? I assume you just take out top and bottom bolt(s) then jack up the engine a bit and pull it out ?
Thanks
https://www.sau.com.au/forums/topic/405384-r34-questions-turbo-e85-mounts-etc/
If your going to that effort get a flex capable ecu and do a proper flex tune, so simple and less risk of any issues....
As for engine mounts, unless they are worn or
Broken then leave them as is...
There are a few options out now and so far they all seem pretty successful.... They are generally MAP.... Mines not P&P so not the best option
As for the clunky, I wouldn't know without hearing or feeling it, it's possible but more likely driveline related?
yeah, i wouldn't bother around with all that if you're running Nistune, get an ECU with a digital input.
You'll find most people run the Link G4's for this sort of thing, or the Vipec equivalent. There is a plug'n'play for the 34's.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
