:headspin: Great turn out, the best thing was seeing soooooooooo many liners all in one place.
Thanks to everyone who turned up. Cant wait to see what the shots, of course I want to see all those crying eyes that were looking into the sun. hehehe.
Thanks again to the SAUWA 'staff' for the setup and to Rick Mcdowell for taking the photo's.
This should be a great way to push our club into the mags. :wassup:
  • Replies 120
great way to spend a sunday arvo good organisation nice people and what should be some neat pics (other than the squinting eyes tee hee) thanks to the organising team and everyone who showed up and made us feel welcome would have hung round for longer but my mate had stuff ta do back in mandurah
Yeah - what Mirkz said!
I enjoyed being part of it and meeting you guys. Thanks to Paul and all for organising it. I wasn't expecting to get in the photo, so that was a bonus. :P (I did wash the car, just in case though!)
Joseph (my son) thought it was cool seeing so many Skylines together - which was a first for me too! Looking forward to seeing the magazine.
Thanks again to the organisers.
Cheers.
PSIKO,
I cant get to this site due to the adultmovies.bz at the start of the link. Is there somewhere else you can post them, just asking dude
Cheers :)
I went to see the photos and then wondered what was in the rest of the site! Very interesting! :Oops:
There are advantages to owning the business and setting the internet access policy!! Fortunately, nobody will notice (or care) that I have now downloaded a load of photos from this site! (Photos of Skylines, that is!!)
Cheers!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
