  • Replies 58
Dude you have posted all sorts of threads....
I assume you meant QUIET?....
Come put of it?....
Thought you said you were in Uni?
One way to get the guys on your side is post up pics of your car etc that you claim to have :)
*accept, sorry
I just wanted some advice, please please read my other thread on general automotive section and please help me. Not a uni student just a kid who gets picked on cause apparently I ride push bikes and sht. So aha. Sorry for being a nusense. I rwly want to be involed in the pretty cool community
*accept, sorry
just don't BS people, you'll get alot more repect that way.
And it is a great community, with a mountain of information - so if you really keen on a skyline when you get on your P's, use the search function and find as many topics about the buying & maintaining the car as possible. THEN ask if your confused or can't find an answer to a question.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
