Ahh but Richard, what offset on a 33 GTS-T? hehe.
I'm running 255/40/r17 on +30 offset rims, the front tyres CAN hit the guards (though the only time they have managed is when I aquaplaned up a 45 deg gutter sigh). Rears have not made contact at all, though unsure if they can in theory.
  • Replies 46
For the rear it will be fine. 265/35/R18
Front 255/35/R18. (35 being a % profile) therefore it will have a smaller tyre wall than the rears
or 255's all round.
It is the offset that matters most, and I wouldn't go larger than +30 GTS_T
I think Kasko's going +22 so will poke out.
Camber, ride hight will come into play.
If it's going to be dumped somewhat then gaurd rolling/pumping may be needed.
Best advice would be Mick out at National Tyre Wharehouse (NTW) Fyshwick :thumbsup:
265/35/R18
9.5 +22 with a 265 will be tight in the back of a 33 gtst but it should fit with a roll. Might be a smidge of poke but meh it wouldn't be much. Can get a light pull of the guards or camber if it's a real issue I guess.
I would run a 235/40 upfront for clearance if it were me.
It all depends on how low the car is as well
Edited by Mitcho_7
Do the tyre places around here let you go test different offsets and tyre sizes on your car?
Just got back from down the coast from a friends 21st.
Now next weekend heading to Sydney for my mums surprise 50th
Anyone got any cruises planned soon.
Zebra you going to do something for your birthday?
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
