Hey guys want to clear up a debate.
Question im asking is as follows. If I had the following 2 tyres 245/18/40 and a 245/20/40 is the actual width of the tyre different or does the 245 stand 24.5cm across the tyre?? I realize the side wall changes in height between the 2 but want to know about the width.
Feel like a dick asking it but figured someone could answer it
https://www.sau.com.au/forums/topic/405801-tyre-sizes-want-some-clarity/
Yes it's different depending on what you're after (and brand of tyre).
The profile is a %, not a set amount, hence it's called profile.
For a visual - use the Miata calc...
http://www.miata.net...e/tirecalc.html
is that how it is written on the tyre, cause that means they are 245mm tread/ 18 and 20% profiles/ and for 40 inch rims ?
if not I'll assume it's 245/40/18 and 245/40/20, 245, is tread width/ 18-20 is rim size in inchs/ 40 is profile which is 40% of the tread width which is 245mm
so yes the width is the same, the profile is the same so the side walls are the same, just the rim size is different one is for 18 inch rims and the other is for 20 inch rims
yes 245 is 245mm of thread width and they are the same width
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
245/40-18 3.9in 12.9in 25.7in 80.8in 784 0.0%
245/40-20 3.9in 13.9in 27.7in 87.1in 728 7.8%
the the width is the same, the profile is the same so the sidewalls are the same, but since they are for different rims there is a 2inch/50.8mm diameter difference which inturn give an circumference difference
Actually tire width is quite complicated. The 245 number does NOT tell you that what the "tread width" is, that is, how much rubber is on the road. You have to look that up from the specs of the tyre, using the 245/40/18 type number as key. Not all manufacturers publish it. Tread width is probably the best dimension to use if you're worried about clearance at its at the periphery where you're going to get rubbing. For example, when i changed tyres to Falken RT-615s (S spec, more track friendly than regular street tyres) i got rubbing at the rear because the Falkens had a wider tread width than the previous tyres, despite both being 255/40/17s. Google it.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
