Also, going to Chasers Motorworks on Monday. Ordering in a Nistune board and also booking in my 90k km service with them.
All up, including service, supply of board and tune should cost me $1100. Hopefully they'll look after me... Cant wait to see the difference after a tune!
Chasers seems alright, a lot of nice show/ race cars are always in there. My old office in the same strip. Good bunch of guys but that was 3 years ago.
  • Replies 47
Let us know how you go with Chasers and the work they do. I would be most interested.
That looks like a nice car. Very rare combo of black, factory RS4s manual and sunroofs. These cars don't come up very often in that factory spec.
thanks mate :) i'm looking at possibly a new front end though... just have nfi what to look for at the moment!!
i wish my rs4s was black :(
I love black, but its a bitch to keep clean!!
Also, looking at a front grill...
These guys alright? Or pain in the arse with shipping and customs??
http://www.nengun.co...t-grille-267702
That won't fit your car as it is for a series one and you've got a series two. Check out Import Monster, I got my NA grill (pretty much the same as the one in your link) through them for about $180, and it only took about a week to get from Japan to Tassie. One like this:
http://www.importmonster.com.au/view?url=http://page21.auctions.yahoo.co.jp/jp/auction/j193572331&thumb=http://auctions.c.yimg.jp/f46batchimg.auctions.yahoo.co.jp/users/0/2/3/2/yuasazidousya2-thumb-1344565546952230.jpg&title=5268
http://www.importmon....jpg&title=5268
Thanks mate. That should fit straight into my S2? Or do you need to modify it further to fit it?
That should fit straight on as far as I know. Series 2 grills have the holes for the fog lights, series 1 grills don't. Apart from that they are pretty standard as far as I am aware. Mine just fitted straight on when I got it.
Ah ok cool..
Now I dunno which will look better on my black C34...
Dont really want to buy both for the sake of seeing which looks nicer haha
Seeing as I'm located in Deer Park and fairly close to you, happy to let you take mine off and trial fit it on yours to make up your mind. :thumbsup:
Mine is the second grill and painted black but it now is a bit flakey, suppose it'll still give you an idea how it'll look.
looks like the auction is finished.. can I still buy it?? this is the one i want now!
Ah ok cool..
I have the second one on my white car, but it has been painted black with the badges unclipped, so no chrome.
I'm happy with it on a white background, might be too much black for a black car.
yeah my heart is set on the other grill, but now i cant find one haha
nice ride dude :) basically Identical to mine, apart from the kit.. I got a dolphin kit on mine.. bit curvy-er
why are you going for a grill ?? just get the silver mesh, looks sweet ... *exhibit A*
thats a sweet front end~!!
any issues with having your cooler exposed with the cops??
also, did you get your mesh at autobarn or somewhere similar??
It came like that imported, but I did notice you can get similar mesh at all the auto (and hardware?) stores :)
never had a problem at all, had the car well over two years now, and not a single problem from the po-po
(considering I've got a carbon fibre hood, bov, fmic, pod, no cat and 3' turbo back... :D)
they prob like... hmmmm volvo... nice volvo... now where's the skyline that has that bov.. *turns head*
I vote get the mesh and see what you think dude .. I think it looks way better than any of the stock grills.
Edited by atomaly
If you are not too sure better to spend less cash and get it looking a little nicer while you make up your mind.
Although most member seem to have stock grills so I'd keep yours
Heres the front of mine with the series two grill if you want to know exactly what yours would look like
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
