Hey guys my 04 v35 coupe is having problems. Everytime I hit the throttle the brake light shows up followed by the slip and VDC off light after a whole the brake light disappears though slip and vdc stay on! It's annoying me and I have done some research, just wanted to know if anyone has had this problem and what was done for it to be fixed...
A few things mentioned were brake pads/brakes mine just hit 40k on the clock which sounds about right when the pads should be worn though my mechanic noted that I could still drive for another 5/10k kms...
Are these lights signs of low brake fluid/pads!? Or is this something else!?
If its the brake fluids should I use dot 3 or 4!? The brake fluid cap on the car states dot 3 only?
Also note the fluid level is half way between max and low so do I need a top off!? Thing is I don't know what the previous owner has used is it alright to mix dot 3 with dot 4!? Or would be best to flush it all first?
Your help and opinions/views would be much appreciated!!
https://www.sau.com.au/forums/topic/406152-brake-lightvdcslip-light/
Sounds familiar have you tried the search engine to see if anyone else has had the same problem? Brake fluid is Dot 4, if it's got dot 3 in it i would flush it. I changed all the fluids when i bought my 03 coupe because i was unsure as to what he used.. I would definitely change brake fluid and check everything else while your there.
Your mechanic doesn't know what the problem is?
The first time I just got him to check my brake pads and not the actual fault itself...so yea through searching the common things mentioned were brake fluids/pads wheel balance/sensor etc.... I have done some searching on here but just wanted to see who else had these issues moreso recently..... So dot 4 is the go? The cap of the brake fluid in the engine states dot 3 only though so not sure ay....
I kinda had a similar issue with mine, after I took it to test and tune, heading back home I went to accelerate and same thing, brakes, vdc and slip turned up and the car stalled. Only happened with VDC off. For some reason it just stopped happening, so unfortunately I dont know the issue. I hope you find the issue.
You need to put a scan tool on your car to find out what error code your car is putting out.
Any good mechanic with have one or do it yourself for cheap. It's like having an onboard computer.
http://www.ebay.com/itm/WIRELESS-BLUETOOTH-OBD-2-OBD2-ODB-II-INTERFACE-SCANTOOL-/110686061333?pt=Motors_Automotive_Tools&hash=item19c5674315&vxp=mtr
Get one of these with an Andriod phone. It will tell you everything about your car as you drive.
Very cool on a tablet.
Chicks Love It :wub:
http://www.ebay.com/...5674315&vxp=mtr
Very good advice! and it's only $20, i just ordered one myself. Could come in handy
First of all, get rid of the brake fluid and replace it with Dot 5. Give the system a complete flush. If the caps got Dot 3 on it, then I wouldn't trust what's in there.
Might be missing something here but can that work with an iPad?
Scan tool should show the fault.
No2 son had a very similar problem with his Aristo, handbrake warning light, TPS light , cruise cut off etc.
Turned out to be a faulty fluid level sender on the brake master cylinder.
Disconnected the plug and fault cured.
Luckily he had a complete spare master cylinder assembly and all fixed.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
