Would someone be kindly enough to post pics up of their AVCR location? Especially if it was installed under a single DIN! I am getting a custom plastic made for it.
Even if it wasn't under the single DIN, please include any mounting position pics of the boost controller. I've searched hours trying to get ideas!
Who has the most professional installation of the thing, I wonder.
Much appreciate it and many thx for your time!
https://www.sau.com.au/forums/topic/40632-apexi-avcr-mounting-place-picture/
http://www.skylinesaustralia.com/forums/sh...ead.php?t=39832
yer dude go there, i have my pics up already just dont want to upload again..
i had my avc-r on the dash before that. looked good but every 1 wanted to race ;)
yes, they look awsome, thanks for the input!
There is no restrictions in other states i think but NSW! (above the dash principle)
I am not sure on that so don't quote me!
This isn't the Boost controller, but i think the RSM is the same size?? even though there are no restricitions in WA about dash mounting, i didn't like the idea of having it stuck in the middle of my dash... all i've done here is remove the dashlight dimmer (which looked aftermarket anyway) and make a plate to fit in the holes left by pulling out those little plates. Cables all fit neatly into the dash and everything !
yer looks alright wld808 mine would be there to cos im thinking of bastards poping my window. but i hate that empty gap i have so i stuck in there.. i hide my turbo timer there tho, i guess urs is more like a "sleeper". (you got ur avcr working normally now?)
when i bought the car the avcr and afc were high up on the dash, was piss easy to move it i just had to cut a small hole in the top of the glovebox for the wires which you cant see. they both work just fine and i now also have the turbo timer with them. they werent even wired up when i bought it i had to do it all. i dont care much about the apexi stuff the only reason i didnt take them out is because it would take a long time to do and i cant use them on my next car. like i said before it would piss me off much more if someone damaged the door or window to steal them.
My friend also did exactly the same as pstanbis, but unfortunately it's not possible in an R33 as all the sensors for the climate control are there in an R33. He also at one stage took out his gauge sluster and mounted it in there with a piece of blanking sheet. That looked much better but I don't think it was all that legal.
thx pstanbis, if it not too much of a hassel.
Pandaemonaeon: yeah, as most of the people are scared of the pricks breaking windows, I am too. So I don't want it any where too obvious. So under the Din is alright. the Sunshade sounds good too. But I wonder how it's all done. And I want it to be undefectable! at least one off the list! LOL
You could do what I have done with my FBC hand controller and use a Flipdown DIN pocket under the H/U. An AVCR is a bit bigger so you would have to cut pieces out of it, but I'm sure it would still work. The flip down pockets should be available from any wrecker as they were in the R32.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
