Hi guys I was going to be putting this into my R32 but circumstances have changed and its time to sell up.
Tomei SR22DET Engine, No Intake or Exhaust Side!
Specs:
New Sr20det Block
Ported, Polished and Flow Benched Head
Machined Block
Full Nissan Gasket Set (Intake/Exhaust Manifold, Rocker Cover Gasket)
Genuine Nissan Timing Chain
Genuine Nissan Oil Pump s15
Genuine Nissan Water Pump
Genuine Nissan S15 Tensioner and Tensioner Bracket (Metal)
Farrera 1mm Over Sized Valves
HKS 278 degree Intake And Exhaust Cams
Tomei Solid Lifters (Lasher Killer Kit)
Tomei Valve Guides
Tomei Test Shimms
Tomei Type B Double Valve springs
Tomei Cam Sprockets
Tomei 2.2L Stroker Crank
Tomei Rods
Tomei Custom Pistons
Tomei Gudion Pins
Tomei Piston Rings
Tomei 1.2mm Head gasket
Tomei Rocker Arm Stoppers
Ceramic Coated Valves and Pistons
Greddy Oil Sump
ARP Head bolts
ARP Rod bolts
ARP Main studs
Nismo big end bearings
Further info: The motor was built by C-red and machine work carried out by Heinz engineering, the motor has approx 10000km's on it.
I have all receipts for the parts and work carried out on the motor.
Other bits the motor will come with:
Nismo Engine Mounts
S13 Crossmember
Alternator and bracket
Starter motor
Brand new S15 7 Layer Exhaust Gasket
Engine Stand
So for all of the above I am chasing $7500.00
Located in Perth but I will consider sending interstate.
I have a heap of other parts I will put up for sale later and maybe able to negotiate with the sale of the motor.
Some of the parts include:
Brand New Greddy Intake Manifold
Brand New Trust Oil Cooler Kit with Thermostat
Z32 Gearbox Conversion, Twin Plate Clutch, Box, Master, Slave and Custom Drive shaft.
PowerFC Djetro with full engine loom
PM me for any questions.
Damon
https://www.sau.com.au/forums/topic/406354-tomei-sr22det/
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
