Ok so I've got a heap of R33 parts, I'll try to make the list as comprehensive as I can, but if you're after something thats not on the list feel free to msg me as I may have it. All parts located in western suburbs of Melb, happy to post anything under 15kg. Prices are cheap!
Can msg pics of anything.
0424999936
S2 Bonnet (white, straight) - 100
RHF guard (white, straight) - 70
Castor rod LHF - 40
Lower control arm RHF - 60
Castor rod brackets - 20 each
Instrument cluster (manual turbo 130ks) - 80
Drivers seat (bolster rip) - 20
Dash - 20
Power steering rack (recod complete from tie rod end to end) - 80
Interior parts - just ask, have heaps
Front subframe with engine mounts - 50
3 inch catback with single cannon 100db - 150
Gearbox mount with bracket - 40
Manual tailshaft - 60
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 700
Injector loom - 20
Coil pack loom S2 - 20
Rear cradle - 80
Diff - 80
Rear swaybar with links - 20
rb25 clutch fan with sr20 fan blade - 10
Front window glass, drivers and passengers - 10 each
Radiator/condensor fan - 10
Standard dump pipe with O2 sensor - 20
Radiator with hoses - 40
FMIC with mounting bracket that replaces front reo, no piping - 100
Manual conversion parts
Pedals - 40
Clutch master cylinder - 40
Clutch metal hard lines - 20
Brake booster - 20
Brake master cylinder (abs) - 40
Drivers window reg with motor - 70
Passenger window reg with motor - 40
Passenger door trim complete - 20
Rear lower control arms - 20 each
Rear upper control arms - 20 each
Half shafts - 30 each
Drivers door (white) - 20
Front 5 stud turbo brake calipers - 180
Rear 5 stud setup (no handbrake cables) - 220
https://www.sau.com.au/forums/topic/406570-soooo-many-33-parts-vic/
  • Replies 68
sold most of the after market stuff off it. had greddy plenum nismo 555cc 2871r and te37s but it's all sold now. still got a really neat fmic with mounting kit for 100 bucks
yeah piping was to suit forward facing plenum unfortunately :(
everyone keep the pm, messages and calls coming! will update the list when things get picked up or sent out today
Updated list!!
Castor rod LHF - 40
Drivers seat (bolster rip) - SOLD
Dash - 20
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - SOLD
Injector loom - SOLD
Coil pack loom S2 - SOLD
Rear cradle - 80
Diff - SOLD
FMIC with mounting bracket that replaces front reo, no piping - SOLD
Pedals - 40
Brake booster - SOLD
Brake master cylinder (abs) - SOLD
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - 60
Rear 5 stud setup (no handbrake cables) - SOLD
Updated list!!
S2 Bonnet (white, straight) - SOLD
Castor rod LHF - 40
S2 AFM air flow meter pink label - 60
Instrument cluster (manual turbo 130ks) - SOLD
Dash - 20
Rear cradle - 80
Diff - SOLD
Pedals - 40
Edited by filipovic
Updated list!! 19.8.2012
S2 Bonnet (white, perfect condition) - 150
RHF guard (white, straight) - 40
RHF guard (white, straight, holes drilled for cable ties) - 20
LHF guard (white, straight, holes drilled for cable ties) - 20
Grille (s2 white excellent condition) - 30
Despoilered boot (white, no holes, excellent condition) - 100
LH Taillight (white) - 40
RH Tailight (white) - 40
Spoiler (s2 in silver) - 50
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - 1500
RB25det manual gearbox (very low KM) - 1300
Heater core - 40
Manual tailshaft x2 - 50 each
Front upper control arms - 10 each
Castor rod LHF x2 - 40
Castor rod RHF - 40
Lower control arm LHF - 60
Lower control arm RHF x2 - 60 each
Castor rod brackets x4 - 20 each
S2 AFM air flow meter pink label x2 - 50
Drivers seat (great condition) - 50
Passenger seat (great condition) - 40
Rear seats (great condition s2) - 60
Dash x2 - 20 each
Dash facia (good condition) - 40
Centre console x2 - 20 each
Gear surround (manual, boot in bad condition) - 20
Steering column lower trim - 20
Glovebox x2 - 20
Seatbelts - 15 each
Sunroof switch - 10
Interior map light - 20
Sunvisors - 10 each
Parcel shelf - 20
Power steering rack (tie rod end to tie rod end) - 50
Front subframe with engine mounts x2 - 50 each
Gearbox mount with bracket x2 - 40 each
Manual tailshaft x2 - 60 each
Rear cradle x2 - 60
Diff (lsd manual ratio) - 120
Diff - SOLD
Rear swaybar with links x2 - 20
rb25 clutch fan (trimmed for cooler piping) - 40
Radiator/condensor fan x2 - 10
Dump pipe with screamer and O2 sensor - 150
Radiator with hoses x2 - 40each
Pedals x2 - 40 each set
Clutch master cylinder x2 - 40 each
Clutch metal hard lines x2 - 20 each set
Brake Booster - 40
Brake master cylinder (non abs) - 60
Passenger door trim complete x2 - 20 each
Drivers door trim (without window switch) - 30
Half shafts x6 - 30 each
Passenger door (white) - 20
Updated list!! 25.8.2012
RHF guard (white, straight, holes drilled for cable ties) - SOLD
LHF guard (white, straight, holes drilled for cable ties) - SOLD
Headlight (s2 RHF missing the bracket where the grille clips) - 40
Headlight (s2 LHF broken on the bottom about 20c piece size missing) - 20
Front shocks (standard but great condition complete with springs) - 30 each
Coilovers (rear, pedders sports rider extreme x) - 300
350z wheels (pair of 17's no gutter rash) - 250
Steering wheel (s2 excellent condition) - 60
Steering wheel (rwc condition) - 20
Airbag (s2 excellent condition) x 2 - 20 each
Indiator stalk - 10
Wiper stalk - 10
Clock spring - 10
Airbag control unit - 10
Strut brace (front) - 50
Strut brace (rear) - 60
Wiper motor - 20
Steering column - 10
LH Taillight (white) - 20
RH Tailight (white) - 20
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - SOLD
Heater core - 40
Castor rod RHF - 40
Dash x2 - 20 each
Gear surround - 20
Glovebox x2 - 20
Seatbelts - 15 each
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Btrims - ask for price
Front subframe with engine mounts x2 - 40 each
Gearbox mount with bracket x2 - 30 each
Rear cradle x2 - 40 each
Diff - SOLD
rb25 clutch fan (trimmed for cooler piping) - SOLD
Radiator with hoses x2 - 30each
Brake Booster - 30
Brake master cylinder (non abs) - 50
Passenger door complete with glass and motor/reg (white) - 80
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - SOLD
Hi mate, i'll grab: rb25 clutch fan with sr20 fan blade - 10
Providing the clutch hub is tight and in working order, and you'll post. (I only really need the viscous hub, don't mind if you send it without the blades).
Cheers.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
