Ok so I've got a heap of R33 parts, I'll try to make the list as comprehensive as I can, but if you're after something thats not on the list feel free to msg me as I may have it. All parts located in western suburbs of Melb, happy to post anything under 15kg. Prices are cheap!
Can msg pics of anything.
0424999936
S2 Bonnet (white, straight) - 100
RHF guard (white, straight) - 70
Castor rod LHF - 40
Lower control arm RHF - 60
Castor rod brackets - 20 each
Instrument cluster (manual turbo 130ks) - 80
Drivers seat (bolster rip) - 20
Dash - 20
Power steering rack (recod complete from tie rod end to end) - 80
Interior parts - just ask, have heaps
Front subframe with engine mounts - 50
3 inch catback with single cannon 100db - 150
Gearbox mount with bracket - 40
Manual tailshaft - 60
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - 700
Injector loom - 20
Coil pack loom S2 - 20
Rear cradle - 80
Diff - 80
Rear swaybar with links - 20
rb25 clutch fan with sr20 fan blade - 10
Front window glass, drivers and passengers - 10 each
Radiator/condensor fan - 10
Standard dump pipe with O2 sensor - 20
Radiator with hoses - 40
FMIC with mounting bracket that replaces front reo, no piping - 100
Manual conversion parts
Pedals - 40
Clutch master cylinder - 40
Clutch metal hard lines - 20
Brake booster - 20
Brake master cylinder (abs) - 40
Drivers window reg with motor - 70
Passenger window reg with motor - 40
Passenger door trim complete - 20
Rear lower control arms - 20 each
Rear upper control arms - 20 each
Half shafts - 30 each
Drivers door (white) - 20
Front 5 stud turbo brake calipers - 180
Rear 5 stud setup (no handbrake cables) - 220
https://www.sau.com.au/forums/topic/406570-soooo-many-33-parts-vic/
  • Replies 68
sold most of the after market stuff off it. had greddy plenum nismo 555cc 2871r and te37s but it's all sold now. still got a really neat fmic with mounting kit for 100 bucks
yeah piping was to suit forward facing plenum unfortunately :(
everyone keep the pm, messages and calls coming! will update the list when things get picked up or sent out today
Updated list!!
Castor rod LHF - 40
Drivers seat (bolster rip) - SOLD
Dash - 20
5 stud conversion (100% complete hubs discs calipers brackets pads handbrake lever and cables) - SOLD
Injector loom - SOLD
Coil pack loom S2 - SOLD
Rear cradle - 80
Diff - SOLD
FMIC with mounting bracket that replaces front reo, no piping - SOLD
Pedals - 40
Brake booster - SOLD
Brake master cylinder (abs) - SOLD
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - 60
Rear 5 stud setup (no handbrake cables) - SOLD
Updated list!!
S2 Bonnet (white, straight) - SOLD
Castor rod LHF - 40
S2 AFM air flow meter pink label - 60
Instrument cluster (manual turbo 130ks) - SOLD
Dash - 20
Rear cradle - 80
Diff - SOLD
Pedals - 40
Edited by filipovic
Updated list!! 19.8.2012
S2 Bonnet (white, perfect condition) - 150
RHF guard (white, straight) - 40
RHF guard (white, straight, holes drilled for cable ties) - 20
LHF guard (white, straight, holes drilled for cable ties) - 20
Grille (s2 white excellent condition) - 30
Despoilered boot (white, no holes, excellent condition) - 100
LH Taillight (white) - 40
RH Tailight (white) - 40
Spoiler (s2 in silver) - 50
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - 1500
RB25det manual gearbox (very low KM) - 1300
Heater core - 40
Manual tailshaft x2 - 50 each
Front upper control arms - 10 each
Castor rod LHF x2 - 40
Castor rod RHF - 40
Lower control arm LHF - 60
Lower control arm RHF x2 - 60 each
Castor rod brackets x4 - 20 each
S2 AFM air flow meter pink label x2 - 50
Drivers seat (great condition) - 50
Passenger seat (great condition) - 40
Rear seats (great condition s2) - 60
Dash x2 - 20 each
Dash facia (good condition) - 40
Centre console x2 - 20 each
Gear surround (manual, boot in bad condition) - 20
Steering column lower trim - 20
Glovebox x2 - 20
Seatbelts - 15 each
Sunroof switch - 10
Interior map light - 20
Sunvisors - 10 each
Parcel shelf - 20
Power steering rack (tie rod end to tie rod end) - 50
Front subframe with engine mounts x2 - 50 each
Gearbox mount with bracket x2 - 40 each
Manual tailshaft x2 - 60 each
Rear cradle x2 - 60
Diff (lsd manual ratio) - 120
Diff - SOLD
Rear swaybar with links x2 - 20
rb25 clutch fan (trimmed for cooler piping) - 40
Radiator/condensor fan x2 - 10
Dump pipe with screamer and O2 sensor - 150
Radiator with hoses x2 - 40each
Pedals x2 - 40 each set
Clutch master cylinder x2 - 40 each
Clutch metal hard lines x2 - 20 each set
Brake Booster - 40
Brake master cylinder (non abs) - 60
Passenger door trim complete x2 - 20 each
Drivers door trim (without window switch) - 30
Half shafts x6 - 30 each
Passenger door (white) - 20
Updated list!! 25.8.2012
RHF guard (white, straight, holes drilled for cable ties) - SOLD
LHF guard (white, straight, holes drilled for cable ties) - SOLD
Headlight (s2 RHF missing the bracket where the grille clips) - 40
Headlight (s2 LHF broken on the bottom about 20c piece size missing) - 20
Front shocks (standard but great condition complete with springs) - 30 each
Coilovers (rear, pedders sports rider extreme x) - 300
350z wheels (pair of 17's no gutter rash) - 250
Steering wheel (s2 excellent condition) - 60
Steering wheel (rwc condition) - 20
Airbag (s2 excellent condition) x 2 - 20 each
Indiator stalk - 10
Wiper stalk - 10
Clock spring - 10
Airbag control unit - 10
Strut brace (front) - 50
Strut brace (rear) - 60
Wiper motor - 20
Steering column - 10
LH Taillight (white) - 20
RH Tailight (white) - 20
RB25det s2 engine (complete with loom, ecu, turbo etc 100% complete, very low KM) - SOLD
Heater core - 40
Castor rod RHF - 40
Dash x2 - 20 each
Gear surround - 20
Glovebox x2 - 20
Seatbelts - 15 each
Sunroof switch - 10
Sunvisors - 10 each
Parcel shelf - 20
Btrims - ask for price
Front subframe with engine mounts x2 - 40 each
Gearbox mount with bracket x2 - 30 each
Rear cradle x2 - 40 each
Diff - SOLD
rb25 clutch fan (trimmed for cooler piping) - SOLD
Radiator with hoses x2 - 30each
Brake Booster - 30
Brake master cylinder (non abs) - 50
Passenger door complete with glass and motor/reg (white) - 80
Front 5 stud turbo brake calipers (missing a seal,caliper slide, and a couple of caliper bolts) - SOLD
Hi mate, i'll grab: rb25 clutch fan with sr20 fan blade - 10
Providing the clutch hub is tight and in working order, and you'll post. (I only really need the viscous hub, don't mind if you send it without the blades).
Cheers.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
