Hey guys,
I have a "noisy" rb26 head. I bought it reconditioned off another guy with camtech cams in it. It was still in the bubble wrap from the head reconditioners when I got it. Since then the motor is finished and running very well and making good power, but it still needs to be looked at as I can't leave it like it is, it's not excessive noise, but definately louder than your average rb26 with noisy injectors clicking away :)
I understand a feeler gauge is used to check between the lifter and cam for excess clearance yes?
Can someone give me a very brief run down on what I have to do in order too check them? I understand the cams might have to come out and back in a few times, I am cool with all that.
Cheers for any help.
All good, I dug up the r32 gtr workshop manual and it's all in there. Must learn to rtfw before posting.
Any pointers that might make life easier for me but, do tell. It looks like that actually use 2 feeler gauges to check it in the manual..
Yes measure the clearance with the lobes pointing up. Write down each measurement and double check them.
Very slow process.
Once u then remove the cams and buckets u need to measure the current shim thickness then add the measurement taken, then remove the required clearance from that total.
What does the workshop manual say as required clearance?
double check your feeler gauges before you start especially if you are going to do as they say and use 2 to get the measurement right, I started doing it this way and gave up and just used the one bent one. I used Precision shims down in vic ( from memory) for the new ones. If doing the job again on a head still on a engine i would probably consider installing a cam stud kit. You will see why.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
