R34 GTT Four door Stripped parts
(SHELL IS GONE)
R34gtt Front seats -$200 with rails
R34 GTR fuel pump with cradle -$150
R34 dash -$100
clutster -$100
climate control -$125
center console -$100
glovebox-$25
Air bag steering wheel-$100
auto shifter-$5
a/c centre vents -$70
a/c side vents -$30 each
door trims -$50 each
window switches $20 each
hood lining -$50
sun visors -$15 each
(heaps of other plastics just inquire if you want something)
R34GTT RB25det NEO 137,000kms motor complete minus turbo -$1500
R34GTT computer loom complete-$150
R34 Highflow turbo -$800
R34 auto triptronic gearbox flex plate converter etc-$300
cross member-$100
steering rack-$150
castor rods with ajustible bushes $100
GTT brakes calipers front and rear slotted rotors front (near new) stock rear $900
Front hubs and knuckes $150 each
Rear hubs -$100 each
lower control arms $80 each
rear cradle with hicas-$100
rear camber arms $25 each
rear toe arms $25 each
Front upper arms $25 each
Reinhard jap made 3" ENR34 SS exhaust with cannon good condition sounds great-$400
R33 GTR radiator with twin thermo fans-$100
AU falcon twin thermo fan setup-$50
R34GTT doors complete-$100 each
Front bar (cut for intercooler) $150
R34GTT/R33 GTR Ohlins Coilovers-$900
Blitz SUS stainless POD filter ok condition-$50 with AFM adapter
R34 tripple guages with autometer smoked volts oil pressure water temp $150
Clear side inticators-$25
BM44 brake master cyclinder with brake booster-$200
18x8.5 18x9.5 Starcorp impuls with tyres-$800
17x9 +22 x4 Sparco light weight wheels-$800
PM for any more info etc everything located in Newcastle
0422646961
Chasing the stereo surround that goes around the din and below the AC controls
AND
The lower dash section between the gear surround and the top of the dash where the gauge cluster is
Must be good condition and need both sent to Adelaide 5067 please
AND
Both items $100 shipped
Hey I'm after the plastic bit under the ash tray and the rear? Thanks
Price listed centre console plastic $100
Hi mate,
What condition are the coilovers in? And just confirming they fit 1999 GTT? Don't happen to know the spring rates off the top of your head do you?
Cheers,
Shazza
Edited by XS80ST
hey shazza... thry were great when thry were in my car handled nicely all dampeners worked fine... not sure on spring rates i belive the part no was nis 10m ? i think i can confirm later if u want ? and yes came from a 98 gtt so thry will fit
Hey, I was just wondering if you are selling the interior door pannels? Also is the steering wheel still in good condition or has the leather started to go on it?
aircon condenser?
yes $100
door cards price is listed $50 each wheel is in pretty good nick
Can you get a picture of the steering wheel without that cover please?
Cheers
posting a pic now
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
