R34 GTT Four door Stripped parts
(SHELL IS GONE)
R34gtt Front seats -$200 with rails
R34 GTR fuel pump with cradle -$150
R34 dash -$100
clutster -$100
climate control -$125
center console -$100
glovebox-$25
Air bag steering wheel-$100
auto shifter-$5
a/c centre vents -$70
a/c side vents -$30 each
door trims -$50 each
window switches $20 each
hood lining -$50
sun visors -$15 each
(heaps of other plastics just inquire if you want something)
R34GTT RB25det NEO 137,000kms motor complete minus turbo -$1500
R34GTT computer loom complete-$150
R34 Highflow turbo -$800
R34 auto triptronic gearbox flex plate converter etc-$300
cross member-$100
steering rack-$150
castor rods with ajustible bushes $100
GTT brakes calipers front and rear slotted rotors front (near new) stock rear $900
Front hubs and knuckes $150 each
Rear hubs -$100 each
lower control arms $80 each
rear cradle with hicas-$100
rear camber arms $25 each
rear toe arms $25 each
Front upper arms $25 each
Reinhard jap made 3" ENR34 SS exhaust with cannon good condition sounds great-$400
R33 GTR radiator with twin thermo fans-$100
AU falcon twin thermo fan setup-$50
R34GTT doors complete-$100 each
Front bar (cut for intercooler) $150
R34GTT/R33 GTR Ohlins Coilovers-$900
Blitz SUS stainless POD filter ok condition-$50 with AFM adapter
R34 tripple guages with autometer smoked volts oil pressure water temp $150
Clear side inticators-$25
BM44 brake master cyclinder with brake booster-$200
18x8.5 18x9.5 Starcorp impuls with tyres-$800
17x9 +22 x4 Sparco light weight wheels-$800
PM for any more info etc everything located in Newcastle
0422646961
Chasing the stereo surround that goes around the din and below the AC controls
AND
The lower dash section between the gear surround and the top of the dash where the gauge cluster is
Must be good condition and need both sent to Adelaide 5067 please
AND
Both items $100 shipped
Hey I'm after the plastic bit under the ash tray and the rear? Thanks
Price listed centre console plastic $100
Hi mate,
What condition are the coilovers in? And just confirming they fit 1999 GTT? Don't happen to know the spring rates off the top of your head do you?
Cheers,
Shazza
Edited by XS80ST
hey shazza... thry were great when thry were in my car handled nicely all dampeners worked fine... not sure on spring rates i belive the part no was nis 10m ? i think i can confirm later if u want ? and yes came from a 98 gtt so thry will fit
Hey, I was just wondering if you are selling the interior door pannels? Also is the steering wheel still in good condition or has the leather started to go on it?
aircon condenser?
yes $100
door cards price is listed $50 each wheel is in pretty good nick
Can you get a picture of the steering wheel without that cover please?
Cheers
posting a pic now
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
