you betta mke it every few months, I can't afford to fly down there every farkin week hehe...
was fun to meet some SAU NSW fellas, on the whole there's more 32's in NSW I reckon than in VIC, spotted waaaay more 32's than 33's. Overall faaar too few imports in Syd compared to melb. All these shitty integras n doof doof machines doin george st laps is startin to depress me. Also my lack of Skyline to own all these doof doof ricers sucks ass.
Dino reminded me of a cross between george clooney n that father dude from better homes n gardens, musta been the silver lining on his head.
Thought I'd make it easy for you guys by wearing a huge "SKYLINES AUSTRALIA" tshirt, but I don' think you guys saw me the first time I walked past you guys. Second time I heard someone say "Skyline" and looked in the direction n saw Carlo (who I recognised from his pic).
I'll be back in July, so maybe another meet then :)
food was great too... i dunno how duncan ate his steak with chilli sauce... quite worrying that taste... I'd go with carlo's pepper sauce... the ranch burger was waaaay too filling.
My only niggle with that place is that they didn't serve Bundy Draught, but they gave me a Bundy n coke :)
As for drinking holes.. Maq Uni bar is mad, cheap drinks and usually there's american international students working the bar. Also what's up with Inferno? I went there like 2 years ago n it was awesome, now I go there n its as good as pizza hut... what's doin?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
