Originally posted by raist60
No offense to the trust and hks coolers but there a ****en ripoff. My avo one is 600x300x90 mm (Bar and plate) whole kit for 1400.
hi, Dude
can you give more detail about your kit? does it include cooler and piping for r33 gtst? thanks
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-65935
The HKS picture looks to be a kit for a 200SX, but it is the same intercooler i installed on my R32 recently.
I too looked at the AVO unit, but check it is the core that as 600x300x90, as i think this may include end tanks. The HKS kit fitted my car with no real dramas, although the pipes are powder coated/painted mild steel and look to have been formed using hydraulic tube bender, (no mandrel bends).
The HKS core itself has tubes that are smaller than my spare GTR core. It would seem to flow well enough as with the cooler installed my boost has gone from10-11 psi to 13-14 psi. It has essentially made my boost controller obsolete, as i leave it turned off and run the std boost which now sits @13-14psi (stock turbo)
As for cooling i have a thermocouple that i want to mount before the manifold, but until then all i can say is that even after 8-9 laps @15psi flat around eastern creek, the inlet of the cooler is very hot to touch, the outlet is still ambient temperature, the crossover pipe behind the radiator is again very hot. So next is HPC coating or a similar solution to heateing of air downstream of IC. Rather agricultural means of testing but it may give you an idea
Is this too much information. In all i found the AVO bar & plate GTR cooler a better option than the GTST kit, but it means custom piping. If the AVO kit is alum piping than i would suggest this may be a better option than HKS
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-65982
The kits comes with everything you need. Cooler / piping / brackets / silicon hose joiner. Its a 600x300x90 mm Bar and Plate cooler. It feeds through the standard piping in left hand front guard. Its awesome. Like i said i paid 1400 bucks from AVO TURBO WORLD in Melbourne.
Thanks for the information. I just rang them, however the price is up to A$1550 full kit (yes, full kit: include everything need to go in, pressure drop 1psi at 15 psi...., new piping incule the pipe ti replace stock pipe) ship to Sydney frieght around 70~90....1 week)
picture here
mmm...sound's good...[
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-66408
+61 (0)3 9584 4499
If they give you any hassle about shipping i can grab it for ya and we can arrange a different way to ship.
Hi, Dude
will you be able to talk a good deal for us ...(thanks in advance!!), consider we some here consider get FMIC? thaks..
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-66409
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
