Originally posted by raist60
No offense to the trust and hks coolers but there a ****en ripoff. My avo one is 600x300x90 mm (Bar and plate) whole kit for 1400.
hi, Dude
can you give more detail about your kit? does it include cooler and piping for r33 gtst? thanks
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-65935
The HKS picture looks to be a kit for a 200SX, but it is the same intercooler i installed on my R32 recently.
I too looked at the AVO unit, but check it is the core that as 600x300x90, as i think this may include end tanks. The HKS kit fitted my car with no real dramas, although the pipes are powder coated/painted mild steel and look to have been formed using hydraulic tube bender, (no mandrel bends).
The HKS core itself has tubes that are smaller than my spare GTR core. It would seem to flow well enough as with the cooler installed my boost has gone from10-11 psi to 13-14 psi. It has essentially made my boost controller obsolete, as i leave it turned off and run the std boost which now sits @13-14psi (stock turbo)
As for cooling i have a thermocouple that i want to mount before the manifold, but until then all i can say is that even after 8-9 laps @15psi flat around eastern creek, the inlet of the cooler is very hot to touch, the outlet is still ambient temperature, the crossover pipe behind the radiator is again very hot. So next is HPC coating or a similar solution to heateing of air downstream of IC. Rather agricultural means of testing but it may give you an idea
Is this too much information. In all i found the AVO bar & plate GTR cooler a better option than the GTST kit, but it means custom piping. If the AVO kit is alum piping than i would suggest this may be a better option than HKS
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-65982
The kits comes with everything you need. Cooler / piping / brackets / silicon hose joiner. Its a 600x300x90 mm Bar and Plate cooler. It feeds through the standard piping in left hand front guard. Its awesome. Like i said i paid 1400 bucks from AVO TURBO WORLD in Melbourne.
Thanks for the information. I just rang them, however the price is up to A$1550 full kit (yes, full kit: include everything need to go in, pressure drop 1psi at 15 psi...., new piping incule the pipe ti replace stock pipe) ship to Sydney frieght around 70~90....1 week)
picture here
mmm...sound's good...[
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-66408
+61 (0)3 9584 4499
If they give you any hassle about shipping i can grab it for ya and we can arrange a different way to ship.
Hi, Dude
will you be able to talk a good deal for us ...(thanks in advance!!), consider we some here consider get FMIC? thaks..
https://www.sau.com.au/forums/topic/4072-intercoolerhelp/#findComment-66409
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
