Up for sale is the set of Lehrmeister wheels I sourced for my R33 skyline build.
these haven't arrived yet and should land in Sydney within a week or two!
Rare, cool looking wheels that'll suit stanced Toyotas or Nissans that want to run a chunky tyre.
Specs:
18x9 +35
18x10 +35
5X114.3
Judging by the photos, condition is fair. Looks to have paint lifting on one or two of the wheels (my other set had this too, must be common).
Hoping to get what I paid for them to get over here.
Price: $1500 ono
I will ship anywhere in Australia, shipping will be $100 Aust wide (NSW would be cheaper)
Located in Liverpool region, NSW.
Will be in my hands within a week or two! Still coming from Japan.
PM me!
Adam.
no idea mate, I'd say around 2 inches. 2nd photo is one of the rear wheels.
If they were in the teens, they wouldn't be this cheap! (nor would I be selling them).
They have landed in Australia! I should have them within a day or two, I'll chuck up more detailed photos too.
Open to offers.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
