I would have loved a coach when I first started.
Even if just to show me how to do the lifts correctly. For a long time I couldn't squat with an olympic bar because of the pain my lower back received Even now with dead lifts there is a slight bow when i bottom out.
I am going to see Trent at PTC Sydney for this coaching to help get it right.
Also find with a good coach (speaking from other sporting activities) I stay motivated for longer and try harder. Wayne Bennett says he doesnt teach his professional players anything new, he just manages them personally.
food for thought.
Sorry I havent been on for so long, very busy, went to Canberra for the States up there, anyway
Rack pulls. We dont do them as they teach bad habits (hitching). We place the plates on blocks so it mimics the way a bar leaves the floor. We have numerous heights.
Half our lifters pull more off a block, the other half less. Not having momentum at a sticking point makes it much harder. Max has pulled 310kg when he was 75kg, he doesnt get much out of them. Zoran pulls 292.5kg off the floor and 270kg off blocks, clearly he needs the "run up" off the floor.
The best exercise for sticking points I feel is pause deads at your sticking point, stop for a count of 2, then finish the rep.
We love deficit reads, not sure it helps off the floor though as you can use more leg drive on a deficit that isnt there off the floor, but its a great exercise regardless. Do them
5x5 and those clowns claiming it and followers who have no idea why it exists
Bill Starr came up with 5 x 5 when he was asked to write a program for high schools in America to use. Initially he wanted squat/dead/incline but most schools didnt have an incline so he switched to bench press. The 5 x 5 is funny. He said the PE teachers using it were not very smart, and would struggle with a different rep/set scheme, he knew that anyone could remember 5 x 5 lol, so all you guys following it thinking your on something special, think again.
The fact is there is no "best" program, but youre doing one cause its easy to remember and some clown put his name to a program Bill wrote out for dumb PE teachers.
The effort is the key.
To those that claim paused benches are only a benefit for comp lifters, lose the ego, no different to full squats and not hitching your deeds, do the movement properly, your joints will thank you for it when you move to "man" weights
Coaches are important for those that have aspirations, a regular guy at a commercial gym does not need one, he doesnt care that mums can rep his squat PB, nor should he, its clearly not why he lifts, its a social outing, so he can tell his mates he lifts etc.
I hope I havent missed anything. Like I said I was in the ACT over the weekend, awesome comp, some great lifting
I'll post some vids
Big mistake, got injured, ruined his comp. Nathan was planning on 415kg squat, 225kg bench and 330kg dead, a 970kg total to break the All Time 110kg equipped record of 965kg
At the top of the squat he hurt his clavicle and rib, didnt take another attempt, took 2 token benches etc, ended up with 910kg
Jack Hobson benched 180kg at 19yo.....very strong kid
I just realised I have no vids from the Vics up
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
