Hey,
Just wondering if anyone here is interested in a group buy for front bumpers, side skirts etc.
The bumpers are from BAUSauto from g35driver, I was quoted $675 shipping just for the Fiberglass 03-04 Sedan KuRookie Front Bumper.
If anyone is interested, pricing and photos can be found on this thread below, this thread is only for the sedans, will be getting more information about the coupe from them.
http://g35driver.com...-place-get.html
Edited by itsRICHARD
They still sell bumpers they're also called http://carbodykits.com/ if you google BAUSauto you can find their facebook page. They're the only authorized dealer for the KuRookie bumpers atm.
For the coupes I don't think there's a thread but you can search Infiniti G35 and your year make on http://carbodykits.com/
Okay, so I really wanna get this front bumper. I was told each box can fit 2 bumpers and some small accessories in them, I'm thinking of getting the KuRookie Front Bumper and maybe the NisRookie Side Skirts, if you are interested, now's the time to tell me which bumper you're after and the year and make of your car so I can put down a list and get a quote.
If you're from Melbourne you can pick it up from me and save money from shipping :D
Also, they told me they have just about every body kit from every brand including their own line, so let me know which you're after and if you want poly or fiberglass (some only come in fiberglass like the KuRookie sadly)
Hi Richard, good initiative, Ive been meaning to get onto this. I'll be at the V meet Friday in any case.
Can you ask them if they have Poly versions of any of the below for a coupe pls? They are just front bars, but I would happily look at a full kit
- Chargespeed
- Kuruma Z
- Inven
Strafe or Klumyzee Version (with or without the CF Splitter)
- Chargespeed
- Kuruma Z
- Inven
Hey Andrew, which year model is your v35?
See you on Friday at the meet :)
Hi Richard, mine is a 2003 coupe.
Thanks again
Hey Andrew,
Just received a reply,
they have the
$350 Poly Urethane Kuruma Z Front Bumper
$350 Poly Urethane Inven Front Bumper
But not the Chargespeed in Poly.
Started a new thread to get the actual group buy started :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
