ok guys going through the garage got heaps of bits here just want it all gone!!!! buy a couple bits get something free etc
bare r33 shell, front hit, straight doors, all glass, cradle, tank, all sus apart from struts/springs
$150 take it away!!! this will be scraped if not taken soon
R33 PARTS
steering rack $50
clutch/accel/brake pedals/bkts $40
stock dump and front pipe $40
stock intercooler $10
stock intake pipe $5
series 2 silver wing $20
silver mirrors $20 pair
passenger window reg/rail $20
series 1 dash $40
handbrake boot great condition $20
pass window switch $10
steering column plastics $10
hicas ECU $30
s1 front grill $20
elec ariel $20
dash surround $20
air con set up, pump, condensor, lines etc (think its complete) $30
power steer res $10
interior lights x2 $5
parcel shelf $10
fan box for air/heater $10
air con box $10
rear pillar plastics $10 pair
drivers silver tailight 2 inch crack in the clear bit down the bottom $10
black outter door handles $10 pair
inner plastic door handles $10 pair
door locks for central locking $20 pair
steering coloumn controls washer stalk, headlight stalk $20
washer stalk $5
set seatbelts $20
stock castor rods/rear camber/toe arms $20 THE LOT
gear boot/metal ring that goes under the console $5 each
hicas unit $10 each
Stainless high mount manifold, heat wrapped $200
Greddy style intake manifold TB adapter already welded to it 280
80mm Throttle Body to suit ^^^^^ $140 or buy both $380
S14 PARTS
clutch slave cylinder $20
tailshaft $40
diff and half shafts $120
stock blue wing $10
carpet grey $20
RANDOM PARTS
Old school carrozzeria CD player and pop out T.V (with remote) 2 units with dbl din bacrket $40
GFB blled valve $30
Splitfire boost gauge (small) $10
mag wheel clock $20 ($49,95 sticker still on it)
used K&N filter with metal AFM adapter $20
set of small block and big block chev pistons/rods ossible reuse, was for a project $40 the lot
may post smaller items or pick up northern suburbs ADELAIDE
pm your number if you need a pic of something!!
Do you have the centre climate, and air conditioning part I really only need the faceplate of it, from the ntre of the dash, R33 s1 ??
Edited by cashie484
  • 4 weeks later...
