See the ripped boot/split metal on the top right of bolt, its the cause of my knock in steering wheel when i do a sudden jolt to the left.
iam on the search for a new one and i need to know the correct name for it. Drivers side Front suspension.
much appreciated. thanks team
Easy to change too, after doing a couple i have learnt you can do them on the car if you need too :)
any few pointers on how to get it off cos i thought the whole arm thingy has to be unbolted with the whole disc rotor out n that..
hmm urethane bushes thanks good advice i was gonna go oem but yeh urethane whiteline it is.
Yeah thats how i did the first side on mine, but if you swing the arm out (protect your guard with somthing) you can tap the old bushes out with a hammer, you just need to hit them at the right angle and they will dislodge and come flying out (I mean that literally too lol).... As for putting them back in i used a huge pair of multi grips but you can use a nut and both with washers or other methods if you are skilled on the tools.
  • 4 months later...
Okay I know this is an old thread but I still haven't got around to changing these Bushings still. Cos had the car re-sprayed and I didn't drive it since then cos I was overseas...it's been about a year since I Haven't changed it and I was gonna go on track next Monday for the first time... will it be alright if I did, I mean taking corners a bit hard or not.
I drove around some winding roads last week and thrashed through the corners and the car seem normal after. And now do u guys think that it will be fine if I went in track?
Cheers ! Thoughts?
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
