Just thought I'd get everyones opinions on upgrades stages for the R33 GTR V-spec.
I have put these stages together so that I can spead my costs, have no massive outlay in one hit, not to repeat labour or parts and still have maximum power for each upgrade
Any comments or changes would be great.
95+ Nissan Skyline R33 GTR V-Spec
STAGE 1.
Apexi Air Filter Kit
HKS Cam Gears Set
Apexi AVC-R
Apexi Power FC
Apexi FC Commander
HKS Front Pipes
HKS Extention Kit
Z32 AFM's
STAGE 1a.
Nismo G Max Twin Plate Clutch
STAGE 2.
Nismo 660+HP Fuel Pump
Sard 700cc Injectors
HKS GT-SS or GT2530 Turbo Kit
STAGE 3.
HKS Oil Cooler Kit
HKS Intercooler Kit
Nismo 320Km Combo Meter
Cheers,
Daniel
https://www.sau.com.au/forums/topic/40798-gtr-upgrade-stages/
Thats a fairly pricey stage 1 you have there.
Generally a stage 1 type upgrade would include a cat back exhaust, pod filters and some cam gears.
I will be interested to see how this progresses as its very similar to my modification plan.
Nick
My opinions:-
i) replace the element in the standard air box rather than worry about he apexi air filters and the hassle of fabricating a CAI box.
ii) I think you can delete the Z32 Air flow meters from stage 1 as the standard units will have plenty of resolution for that level of mods.
Here's what I think based on my GTR stages....
STAGE 1. (You should hit 250-270 at the rears on 15psi stock turbos)
HKS Cam Gears Set
Apexi Power FC
Apexi FC Commander
HKS Front Pipes - < or save some money and get an exhaust shop to custom some 2.5 into 3in for you around $400fitted
+ Boost Controller - I chose HKS EVC 3 or 4, much better than a AVC-R
+ Hi flow cat back system
+approx labour cost and tune excluding parts $600-1K
HKS Extention Kit - < Found no real gain compared to my stock GTR dumps
Apexi AVC-R - < Go the HKS EVC 3 or 4, holds boost perfectly
Z32 AFM's - < moved to stage 2
Apexi Air Filter Kit - < replace the filter instead, and keep the standard box
STAGE 2. (you should hit around 300 - 330kw on the rears on 18-20psi)
Z32 AFM's
Nismo 660+HP Fuel Pump - < or Bosch 044
Nismo G Max Twin Plate Clutch - Any twin plate
+approx labour cost and tune excluding parts $2-2.5K
STAGE 3. (optional)
HKS Oil Cooler Kit - < dont bother if your not doing track work
HKS Intercooler Kit - < around the 300-330kw the stock cooler is good enough
Nismo 320Km Combo Meter - < please add soy sauce with my rice
+ Catch Can - < you didn't mentioned this but its a precautionary messaure
Mesh;
This is interesting. I'm contemplating a choice of dump pipes at the moment and recently posted a link to an article that was written (so it appears anyway)
by a Garrett Engineer.
My mods will be:
N1s, Tomei Stage1 PONCAMs, pulleys, 700cc inj, Sard reg and pump, standard airbox w/ K and N, exhaust, tune, dumps (?)
The problem that I'm finding is that no one can provide objective evidence to support the use of either the HKS short wastegate pipe, Trust long wastegate pipe, or open bellmouth type designs; consensus appears to be that of the above the long pipe will be best, but all will perform better than the standard units.
Could I ask what your experience was please?
Hi Scooby,
Logic & tuners (inc mine) says a dump will have it's benfits, however they are minimal less than <3kw for the added cost of $600+ for HKS Dumps, and $1000+for the trust. My GTR has the stock dumps at the moment and makes 320kw on 19~psi. Personally next time I might go the trust as it is a single piece which include the dumps and the front pipe, as the cost works out the same as buying the pieces individually.
I completed in 2 stages similar to that above, "just waiting for my OS Giken Twin Plate to arrive" see my link.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=39742
powerFC isn't needed in stage 1 - im running ~270rwkw without a powerfc, but it is definatly needed for stage2
meshmesh - where are you getting your clutch from? how much if you don't mind me asking
Hi ferni, I thought your ECU was re-chipped or something?
The clutch is costing me around $2K from japan
Scooby,
Same problem I had, so I took the word of my tuners who have tested it on a dyno, and it seems they were correct. You also said you wanted to go Trust Stage 1 Cams.. were you thinking 256's? As I also looked into the same cams, and after some full on punch ons with my tuners & others alike I decide to go with their advice "again" and not install cams. Here's why, as a general statement related to Stock GTR Rb26 motors, there are a few things you need to consider and they all come back to longevity of the Stock motor. Sure cams will help, but they will add alot of stress on the motor like many things. I've based my tune & upgrades very conservatively, and know "for a fact" that we can get 400rwkw from my exact same set up... dont believe it speak to Emre. So keeping that in mind my tune at around 320kw is quite safe. My future thought is if I choose to rebuild the motor then I will definately go the cams, full house etc etc.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
