Hi guys it has been awhile since my last cruise so i have decided to
create one. I know it's a bit selfish of me making it a friday morning because of my dayoff but we'l see if how many can or can't go and we can probably change the date and time but we'l see how we go first.
Meet Location - IKEA Springvale 917 Princes Highway Springvale VIC 3171 [parking level 2]
When: Friday 07/09/2012
10:30am for a 11:30am departure
Still undecided but theres 3 destinations I can think of.
Any suggestions would be great though.
Great Ocean Road, Phillip Island & Lakes Entrance
What to Bring: basically a full petrol and a good attitude.
You know how it is....good behaviour = fun and safe cruise....
https://www.sau.com.au/forums/topic/408234-meetgreetcruise-friday-07092012/
  • Replies 84
Set a route please - this is in the guidelines.
There is no way people are going to come if you say "we might be going to GOR, or PI". They are two ends of the state, add to the fact GOR from Springvale is madness. You wouldn't get back to Melb till 8pm at the earliest when you think we usually depart LARA at 10:30am and still don't make it back before 5pm on most occasions.
Yep will do but still undecided of where to go depends on who is definitely down though those were just examples but definitely will decide closer to the date so far it's for friday night just waiting for more responses.
That's only 6 days away >.>
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
