Hi guys,
just wondering if anyone has sanded, prepared and painted their own rims and if so was it difficult and worth it?
i have wheels now that need to be re painted and have been quoted around a $1000 for most places, i love the look of them and dont want to buy new ones as these really suit the car.
any input is appreciated :)
Hi guys,
Yes done a few sets
depends on , tools you have like compressor , sandblaster, spray gun, respirator and clean place to do it
if tyres are off ? Valves out much easier
damage to rims like rash
What you want to paint them in ? colour wise
did my 34 rims with a rattle can the night before a show from pearl white to qm1 lol not the best but didnt take off tyres either , going to soda blast and respray when it warms up more tyres and valves out !!
Worth it yes , be easier if i had free tyre removal and remount and a daily driver to use while off
Edited by Carbon 34
ive restored a set of completely gutter f**ked alloys. they look mint.... but was too much work for the money saved. $1000 will buy you a good set of alloys on any forum and save the skin on your knuckles
There's a mightycarmods video on YouTube which shows you how to do it.
I've personally done this about 6-7 times. Spray painting them can work really well (especially considering you won't be spending much) if you take the effort to properly prepare your wheels prior to spraying.
Get yourself sandpaper and work your way up the grits and finish with a 1500 grit sand (don't go too smooth otherwise paint won't stick properly). Obviously if your wheels have gutter rash etc., you may need to do some filling. After the prep work is done remove all the crap with a good wax and grease remover and mask up the valves. I use cards and wedge them between the wheel and tyre so as to not get any overspray on the tyres (much easier than masking) and then you wanna spray a few coats of primer, when dry a few coats of your actual color spray and finish off with multiple coats of clear (at least 4). After the paint is completely dry wet sand lightly using 2000 grit sandpaper.
The type of paint you use is also very important - I generally find that any high temp enamel spray works well (engine enamel, caliper paint or actual wheel paint).
Tip: don't spray too close, or on one spot for too long as you'll get runs which are ok if it's on your primer (as you can sand away) but will stuff up the look of your wheels if on your color or clear spray.
Dont paint your rims yourself , i just get my sets sandblasted and powdercoated , the finish is amazing and hard wearing .
Ring Oleg at HWH Powder Coaters Edwardstown , Oleg sandblasted and powdercoated my work VS-XX for $90 each -
Heres my thread
http://www.skylinesa...iece-work-rims/
Edited by NISSAN GTR
best bet is powdercoating in above post ^^
but if you want to do a DIY and cant afford to have wheels separated rebalanced and etc (unless your tyres are now racing slicks :P)
have had wheels painted at our crash shop before, not all that difficult just takes a long time, as mentioned in above posts, start off with a coarse fine grit (approx 500) and work up from there to say 800, i would suggest using it wet not dry and even use some scotchbrite for thoes areas u cant reach for good measure.
you can use an etch primer for the area of which u have repaired (gutter rash) sand them back using same method untill your happy with them.
then apply a "drop coat" which is a light coating of the colour you want, alternatively, if your going for a colour which doesnt cover very well put down a basecoat of black but only mist it on (that goes for the dropcoat and basecoat)
then apply how many ever layers of paint desired to reach aquired colour/depth always allow for drying time and finish with a few coats of clear.
important tip is to take time in masking the wheels up properly and make sure all the air is out of the tyres so its easier to compress the sidewall to get tape in there, also a few newspapers come in handy if you dont have the proper stuff to cover them. 1 and 2 inch masking tape will work for this application also.
hope this helps as ive tried to cover what i can remmeber from the painters telling me!
where is your shop mate?im looking at getting a 2pac setup for my self as im ok with painting acrylics, but if i can get my ford BA bodykit done in shop at a good price i will.
You could plasti-dip them yourself, no sanding needed, its lasted ok so far on mine, but if theres a scratch you just spray over the top and its like new again :D
$30 a can, 2 cans will do all your rims
plus you can always divert to the old colour when you please :woot:
Pm'd :D
I dont the colour jet and have some old impuls too.
Your on Australian ford forums as i recognise that car, im 'Sprint' on there.
All fitted and sorted now , the 245 went on the 10.5 so easy , like butter!
Edited by cosworth1971
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
