  • Replies 126
Poor poor Gallardo...
I *cannot* wait to chop that lambo :P here come the hazard lights :)
BTW we currently have accomodation sorted for myself, Kel, Dan, Pete, Jody, Jane, Akira, Kyle, Carlo, Darren, Tosh. Better let me know if anyone else is coming along for sure...tim? dino?
So I have to go to god dammned Golburn to cheer you guys on - OR take the day off on Monday to watch you at EC.....
Hmmmm - Long trip and cold weather versus Day off work and short drive up to EC versus get the sack for having too many days off going to track days
decisions decisions
Pete/Duncan..
Can either of you get me a list of the cars entered by SAU peoples and their numbers so I can try and make sure I get some good photos for you guys..
So Far.. That I am aware of....
Car Number: 12
Car: Skyline R32 GTSt
Driver/s: mchaplin
Car Number: 32
Car: Skyline R31 GTS-x
Driver/s: Pete & Duncan
Car Number: 33
Car: Nissan 350Z
Driver/s: Kelly & Daniel
Car Number: 17 ???
Car: Lancer Evo VIII
Driver/s: Simmo
and from PerformanceForums
Car Number: TBA
Car: Lancer EVO 1
Drivers: itsnotagsr & rotaute
actually Jason, ur list above is all the ones I know about at the moment.....if we spot any more we I'll give you a shout on the weekend :D
all ready to go? coz we aren't....yet.....
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
