  • Replies 126
Poor poor Gallardo...
I *cannot* wait to chop that lambo :P here come the hazard lights :)
BTW we currently have accomodation sorted for myself, Kel, Dan, Pete, Jody, Jane, Akira, Kyle, Carlo, Darren, Tosh. Better let me know if anyone else is coming along for sure...tim? dino?
So I have to go to god dammned Golburn to cheer you guys on - OR take the day off on Monday to watch you at EC.....
Hmmmm - Long trip and cold weather versus Day off work and short drive up to EC versus get the sack for having too many days off going to track days
decisions decisions
Pete/Duncan..
Can either of you get me a list of the cars entered by SAU peoples and their numbers so I can try and make sure I get some good photos for you guys..
So Far.. That I am aware of....
Car Number: 12
Car: Skyline R32 GTSt
Driver/s: mchaplin
Car Number: 32
Car: Skyline R31 GTS-x
Driver/s: Pete & Duncan
Car Number: 33
Car: Nissan 350Z
Driver/s: Kelly & Daniel
Car Number: 17 ???
Car: Lancer Evo VIII
Driver/s: Simmo
and from PerformanceForums
Car Number: TBA
Car: Lancer EVO 1
Drivers: itsnotagsr & rotaute
actually Jason, ur list above is all the ones I know about at the moment.....if we spot any more we I'll give you a shout on the weekend :D
all ready to go? coz we aren't....yet.....
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
