Hey guys,
Looking at selling my pride and joy of the last 5 years...
Due to getting a side job im needing a ute and got a young family that will probably grow in a few years, need a car that i can chuck all the gear in and go out with the family in.
I purchased the car in totally stock form.
Mods so far...
-Nistune Computer fitted and tuned by Envy imports at brookvale. made 221kw atw on their dyno , didnt get a photo or print out.. got a photo at 216kw
- Just Jap oil cooler and relocation kit. Oil filter now located infront of radiator, easy access compared to the factory location!!
- Just jap FMIC
- Nardi copy steering wheel
- D1 detachable hub for steering wheel
- Boss kit ( got off a fellow sau member, is genuine Boss tho)
- Cusco 6 point bolt in roll cage, padded all round
- Fire extinguisher mounted to rollcage
- Splitfire coil packs
- Cusco brake master cylinder stopper - Not fitted but included in the price
- Whiteline Front and rear sway bars, got them from Daleo on the forum as appart of a Group Buy
Front BNF22X 27mm Non adjustable
Rear BNR11XX 24mm Motorsport adjustable
- OS Giken 2 way diff, with the OS Giken oil 80w250 grade aswell, this stuff is expensive around $80.00 per ltr!!
- Drift works Solid Diff bushes
- Driftworks Solid Metal subframe bushes
- 5% window tint all round, installed by Unique window tint, one of the best tint people in sydney
- Optima red top battery 800cca
- Battery to boot relocation
- Isolation switch in engine bay
- Hicas Lock out bar
There are probably things i have forgotten, but ill add them on as i come accross them!!
Car has 88,000 kms on it
$22,000
If you have any questions please post up or PM me..
Can be contacted on my mobile 0424 703 213, if i dont answer send me a txt and ill get back to you asap!!
Enjoy!!
https://www.sau.com.au/forums/topic/408677-fs-r34-gtt-2000-model-with-mods/
Hi Mick,
I sent you several PMs regarding something else, could you please respond to me when you have the chance?
Cheers,
Johnny
Edited by johnnilicte
  • 2 months later...
  • 3 months later...
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
