  • Replies 49
Posted Images
the wrap is very good, theres some untidy bits around the side mirrors and spoilers, but thats to be expected cause the amount of curves and what not, but that will be replaced with carbon fibre bits later on. wrap is easy enough to maintain, im not scared of getting scratches cause i can easily re-wrap the panel. it does get dirty easily but i love the colour and a quick rinse with water and chamois and ur good to go.
just installed the rims a few days ago... here are the pics.
GOD DAMN that is one sexy mutha fker!! love the ADV1 wheels.
Yah we own the hardware store. :P Just got the car tuned at CRD a couple weeks ago...
And thats with these phat ass wheels/tyres... Saving up for some mods.... this car has sent me broke dammit!
Edited by hzrdus
No way! I grab quite a lot of things there.. Nice to know where my money went ;)
SAU:NSW Discounts? :wub:
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
