18x10 +15 offset 265 all round,i was thinking of getting these 8mm or 10mm stick straight on to the hubs, would it f**k the 4WD puting these on at all??
cheersImage2
Edited by Turbo tommy
Ok.
My wheels sit flush, as in borderline flush. Seeing as you dont want to go past the guard then you will have to try and match those wheels or run too much and then you will have to run camber to get them into the guard.
My and your wheels are exactly the same, except for the fact that you 0.5" less on wheel width.
So by me using the good old offset calculator that seems to be a unheard mistery, you can easily see that you have 6mm space between your wheel and guard. Therefor if you want the flush look you need 6mm spacers. And im pretty sure you cant get those.
get some 5mm slip ons, maybe an 8 or 10 for the front if you run a bit of camber, and see what you think. theyre pretty cheap from sprints, autobarn etc.
any more than an a 10mm slip on and you will wanna get some longer wheel studs
you have to have the same width all round???? probs just go the 5mm stick ons all round, not alloy ones though ive heard badc things about them..Anyone know where to get the good stick on spacers from??
ok thanks for that,hadouken you think 5mm spacers should do the trick or should i go 8mm-10mm on my set up??yeh i dont want it to be un even would look crap.. just want it to look that more fatter stance.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
