Hey guys
I just recently sold my R32 Stock airbox (Taken from my old R32 GTST).
However, since they were unable to pay I am now selling it again.
The box is IMMACULATE, as in no cracks, cuts, breaks (with all clips intact and all parts fully working), lower air snorkel included.
Perfect if you want to return back to stock or to clear defects.
I am after $300 for it because of its condition (and because I know how rare these are as it took me over a year to find it for my car)
More pictures / Higher Res photos can be supplied if required.
I can post anywhere in Australia if required.
Regards
https://www.sau.com.au/forums/topic/409332-selling-r32-stock-airbox/
  • 3 weeks later...
  • 3 months later...
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
