Hi Guys,
Time to sell my pride and joy, would be looking to downgrade so open to swaps of cheaper cars with money my way.
I bought this car off another member around a year ago. The car has not changed much appearance wise but I have fixed up a few things mechanically.
I have receipts totalling $6,000 plus many more receipts from previous owners. Plus some good information on the history of the car.
Any interested buyers could you please message me on here and we can sort out a deal.
LOCATED IN BRISBANE
I will be asking $17,500 or closest offer.
Mod list as follows -
Engine and drive train -
- Original matching number engine (verified)
- R34 late model injectors
- Mines cast alloy angles with brand new 4.5" K&N filters
- Custom made front mount oil cooler with earls braided lines. (also a custom made air-con condenser to fit next to the oil cooler)
- Genuine TRUST aftermarket front mount (confirmed)
- Custom Tuned ECU Tuned by RACEPACE producing around 240kw (have dyno sheets)
- Aftermarket 3" mandrel bent straight through exhaust with 4" cannon.
- Trust Front Pipes 2.5" into 3"
- Nismo single plate clutch
- Very tight aftermarket 2-way diff
Suspension / Braking:
- Apexi N1 Evolution Pro Spec Coilovers 12kg front 10kg rears.
- Genuine Nissan OEM Lower Control Arm Inner and Outer Ball Joints Replaced @ 99000km (have recipts)
- Front and rear adjustable strut braces
- Original GTR brakes with the rear rotors replaced @ 93000km .. pull's up a treat.
- Tomei Brake Master Stopper
- HEL Braided Brake Lines front and rear fitted @ ~100,000
- HEL Braided Clutch Line fitted @ ~100,000
Interior:
- Factory GTR bucket seats
- Factory Speakers
- Alpine iPod compatible headunit + bluetooth etc etc
- Nardi steering wheel + boss kit
Exterior -
- GTR N1 front bar
- GTR N1 bonnet lip spoiler
- GTR N1 FRP Bootlip (Justjap copy) - proffesionaly paint matched and fitted by Cobalt Smash Repairs ~102,000kms
- Standard GTR side skirts, rear bar and wing
- Factory forged R32 GTR wheels in pretty good condition
- Enkei RPF1 18 x 9.5 +15 wrapped in Falken 595SS's
- HID headlights 6500k
Photos -
Edited by mjw89
https://www.sau.com.au/forums/topic/409760-1991-nissan-skyline-r32-gtr/
awesome car , i lurve the look off it !! , , im looking at getting a R32 GTR , , but unfortunatly i wont have the money until about 8months , , i had a R33 Gts-t years ago and i miss it , ,
how much KW's would yours be putting out ?? , , and also a general question , , how much KW's does a R32 GTR have to have (a relalistic figure would be nice) to put a smile on your face when driving it ?? , , :D :D
Edited by rodneymc18
haha yeah mate it is great to drive! it has around 240kw, standard puts out around 200 or so kw i think.
engine is fairly stock. if it is still for sale when you have money you are welcome to come check it out.
thanks
  • 3 weeks later...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
