Hey all,
I have a few thermofans left over from previous project cars and I'm after advice on which fan(s) are best suited to an R32 GTR.
I have:
-Spal 16" skew blade puller, is about 85mm thick where motor is.
-Or 2x Spal 12" skew blade pullers.
Just after some confirmation on which setup I should keep before I list on ebay.
Cheers.
just search their cfm rating.
Odds on there wouldnt be much in it. So it would otherwise lead to what would be easier to fit (properly) with an associated shroud and thermoswitch n relay etc...
Iv got twin 12" thermos on a 52mm radiator + shroud n i had to mod the fan n the power steering pipe a bit so that it would all fit without interference.
A smaller radiator would be no issue tho. But if you were going to go this size id reccomend going for the big single.
hehehe, in skylines it all comes back to the big single or twins debate doesnt it... :P
It's hard to convince people that
really? i thought it was the other way around?
even as a thermofan user id agree that the stock fan does move more than enough air, also it is self regulating on how hard it 'pulls' based on the temps encountered.
The advantage of thermofans is that they dont run all the time and therefore take power from the motor at all times like the stock fan. In fact with my 52mm alloy radiator the thermofans dont even come on in the winter months unless i get into stop start traffic. Even then they only come on for about 90-120 seconds per cycle.
Also that the old clutch fans are often wearing out n becoming unreliable. Therefore alternatives are worh considering.
Edited by jjman
the power lost by a clutch fan is bugger all, especially since it only engages fully at higher temps. thermo fans don't have a direct drag on the motor, but they increase the load on the alternator, which puts more load on the engine. so they aren't a free power mod as some people believe.
a big fan draws more air than a small fan as it's the tips of the fan that draw the most air as they are travelling faster than the middle of the fan (same rpm, but they travel a further distance). plenty of cars with thermo fans run 2 fans as it allows them to have different stages of cooling. for example, in some cars, in normal conditions/temps, one fan is used for engine cooling, while the other will come on when the air con is turned on.
as for looking for alternatives, sure you could look at fitting thermos, or you could just buy a new clutch for the fan.
personally, if i was going to run a thermo setup, i'd just use the factory setup off another car, and trim the shrouds as need be. i'd be looking at something off a late model falcon, magna or of a smaller fwd car such as a pulsar, corolla, etc. i'd just find something with a similar sized radiator and go from there.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
