hang on...you were buying only to import it then sell it to make money....you ask an online forum *after* you pay for it what it would be worth....and then you say its bullsh1t that $500 isn't refundable?
who said i was going to sell it straight away.. i would be selling it about a year later...
why is everyine saying im in it to make a bit of money..
I said my main goal was to not loose any money when I sell it.. It says it up there in the 1st post.............................So i dont know why every1 is going on abou tthat 4.
Selling a car is a prick, and every ass wants to "get a deal" and pay less than its worth.
Selling a car is prick.
The beauty, however, is that cars always sell for what they're worth, that's what they're worth to the buyer not the seller, and that's the way it will always be.
I'd say most owners are far too attached to their car to be objective. At the end of the day it's 15+ year old out of date car that's not getting any newer, to expect to get near 27k for it down the line is wishful thinking.
Ask yourself, would you pay around 27k for what will going on a 17 year old thrashed out piece of claptrap in 2005/6? You'd have to be nuts.
89 sell for 400-700k yen +fob
modifed ones are cheaper
so that orks out to about 15k on the road
so its not a wish... there is one sitting im my garadge
not 89 are selling for more now because of demand pushing bu price up to about 800k yen
i know of at least 6 other 89 gtr bought for a similar price
for the cars i have seen a 800k one would be very tidy with some tasty mods
even the 600k one are very nice
400k will have some rust(generally at the rear of the doors or whee they have been hit(all of them have been hit)
and im sure all the engine are pretty tired but its getting cheap to rebuild gtr motors
Are you in Australia?
Would you sell that for 15k?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
