Hi guys, due to certain circumstances I need to sell all my gear for my gtst.
Items are located in the Hunter Valley NSW but can be posted at buyers expense or by other arrangement with myself.
Purchased a brand new set of Tomei Poncams and springs earlier this year from Nengun. Items are still brand new in the packaging they came from japan in
Cams - Nissan - Skyline - ECR33 - 8/1993-9/1997 - Duration: IN,EX 256 Lift: IN,EX 8.5mm
Springs - Nissan - Skyline - ECR33 - RB25DET - Type A - Lift 8.80
Purchased these brand new for $1300 - wanting $1200 - No need to wait a week to recieve them
Nismo Coil over suspension for R33 GTST - Front and rear. Damper Adjustable only. Still in brand new condition, never taken out of the box. - $1000
Apexi Power Fc with hand controller - used. $1250
Z32 AFMS - purchased off another forum member from his GTR - has twin to single adapter. No plugs - $250
Willians 4 point harness, still brand new and never used. Out of date for competitions tho - fine for street use - $100
SSR Integral rims - I think these are copies but unsure. 18x8 +30 offset. comes with 4 tyres. most still 80% 1 %20 - $750
Stainless Steel Catch Can - $50
Front Bar to fit Series 2 - Is a fibreglass but told its original - painted in grey colour. - $400
Fog lights for Series 2 - $200
Can either contact myself via SMS - 0416294030 or email [email protected]
https://www.sau.com.au/forums/topic/410050-r33-gtst-performance-parts/
Purchased these brand new for $1300 - wanting $1200 - No need to wait a week to recieve them - Price Drop $1000
Apexi Power Fc with hand controller - used. $1250 - Price Drop $1000
Z32 AFMS - purchased off another forum member from his GTR - has twin to single adapter. No plugs - $250 - Price Drop $200
Willians 4 point harness, still brand new and never used. Out of date for competitions tho - fine for street use - $100 - Price Drop $50
SSR Integral rims - I think these are copies but unsure. 18x8 +30 offset. comes with 4 tyres. most still 80% 1 %20 - $750 - Sold
Front Bar to fit Series 2 - Is a fibreglass but told its original - painted in grey colour. - $400 - Price Drop $300
Fog lights for Series 2 - $200 - Price Drop $150
Edited by KamikazeR33
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
