Hello again,
I was chasing some info on what camshafts - aftermarket - are good for an r32 GTR? If you put in just cams does any other aspect of the motor need to be changed as well? Was also thinking about getting bigger injectors so any help would be appreciated.
Cheers.
https://www.sau.com.au/forums/topic/410073-aftermarket-camshafts-and-injectors/
Depends on what you are chasing as to what you can/should get. If you are after mega power than an injector upgrade would/should be on the cards. Are you going onto e85 fuel? Bigger turbos?
Yeah as Krishy said bud.
Changing cams over needs to be at the bottom of your list. Plenty other things you should look at first.
Bigger injectors, fuel pump, ECU upgrade, better fmic, exhaust, bigger cans (actuators) (or even bigger turbos) then take it to Willalls and get the thing tuned.
Then you'll have to start thinking about oil catch cans, etc.
Unless you've already got all the above, don't even worry about cams yet.
Cheers guys, I ordered a set of 550cc injectors and I wasn't going to worry about cams. However I was getting the head pressure tested and they found a hairline crack in one of the standard cams. So I thought that I would get aftermarket ones instead of a pair standard ones. I got a catch can and oil cooler. I hadn't planned on engine work but wanna get it right this time. Just planned to run on premium with a set of n1 turbos later down the track.
If you are going to have to replace the cams than I guess it will be worthwhile looking into some aftermarket ones but for just an upgrade for upgrade's sake is not worth it :)
Ok cheers for the advice, I'll keep looking around. One of these days it'll be back on the road and i'm sure the increasingly longer wait will be worth it.
If you need a replacement intake side camshaft, I have one sitting in my shed I can part with - have an exhaust side too but the half moon is snapped off so probably can't sell that one
-D
-D
Cheers for that mate but, it's the exhaust cam that is cracked. With my small amount of expertise, was looking at maybe a set of Tomei Poncam type a or b.
Koji at JIS has some Step 1 HKS cams for an RB26 for $395
http://japaneseimportspares.com.au/enginemodscam/
-D
Yeah I picked up the oil cooler off of here last week after it was suggested and saved a bit in the process. What do you think about 'rust marks'? Be good being in Adelaide as well.
I don't know about the rust issue - you'd probably be best off asking a mechanic/engineer what can be done about that
-D
There are heaps of cheap oil coolers on the market nowadays mate. Just have to shop around and keep a look out. As I said before, personally, I won't be using any second hand coolers. Get a cheap china copy cooler for a couple of hundred bucks. I have been running mine for almost 3 years now without any issues so far. Has done a couple of track days and has no skipped a beat. Keeps the oil cool :D
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
