Hi guys, I've got a R34 GT-T and i finally floored it to about 7RPM and noticed that a cloud of white smoke came out of the exhaust behind me. I've searched around and a lot of people say its either a coolant leak or a turbo on its way out.
My cars running about 10psi. Is there any other signs that i should look for to find out if my turbo is on its way? It seems to hold boost fine and hasn't lost any power.
And because of this im wondering how much a replacement turbo would be, im curious about the price of the cheapest one that will do the job, and approximately how much people charge to install them.
Thanks heaps guys
The hardest thing for most people is identifying what colour it REALLY is.
I would take it somewhere to have it checked.
When your engine pings, the smoke it will spit out can look white in the mirror but its not. It could also be spitting a bit if oil out the breather on the cam cover and burning it through the engine. Any if those things are easily fixed if identified.
Thanks heaps guys
when you say the "cheapest one" are you talking about a stock secondhand turbo or rebuilt turbo or a hi flow or what? as they are all different prices
well i red lined first and second again and no smoke this time. what does this mean? and i really cant get to the turbo without removing parts first, or is it reachable from underneath or something?
For piece of mind as Jez mentioned comp and leakdown test.
Nothing worse than worrying - could be something could be nothing but believe me you need to know now.
Longer you leave things the more expensive it gets. Take it to a trustworthy shop/mechanic.
because hig
I presume it is smoke from burnt oil. It does sounds like a turbo issue.
At high RPMs there are greater amount of thrust load on bearing collars causing greater amount of shaft movement or gap, allowing greater amount of oil escaping from the rear end seal. Plus in 4th gear it takes longer reaching 7000 rpms which also means more time given. So there is a leak just the amount its leaking and the given time for leakage is not great in lower gears, which you might not be able to notice it while driving.
Check and make sure engine is not over filled, and oil drain is not blocked. Remove the intake pipe and have a feel of the turbo shaft movement.
Strip the turbo is easy. you can get every thing down from the top.
because hig
You don't think it's more likely the standard breather system is pumping oil out in front of the turbo?
I would say that is more likely than blockages in factory drain hoses
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
