Evening fellow skyline owners:)
As of today i am the proud new owner of a 1993 R32 GT-R:D . Just have to sought out rego and a little paperwork and i will be driving around in one of my dream cars in a couple of days. I will post some pictures when i bring her home:cool: .
A little info:
Red metallic
89 000 kays on the clock
HKS FMC
18" volk racing rims (very very nice)
Everything else is standard, a great base to start from i think. What do you guys think.
https://www.sau.com.au/forums/topic/4102-finally/
erin - i might see you around the coast, ill sms you if i have my car etc.. if i can organise somethin.. i might meet you guys in brissy possibly, depending on fuel .. etc.. but yeah.. if i dont cruise with you and you see a nice blue r32, with stock silvia wheels.. you know who it is.
https://www.sau.com.au/forums/topic/4102-finally/#findComment-66004
Blue? You changed the colour? I didn't know that.
ewps.. sorry for hijacking the thread!
https://www.sau.com.au/forums/topic/4102-finally/#findComment-66126
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
