  • Replies 321
Posted Images
If I'm not hungover and it's a nice morning I'll meet up at Kariong in the 5 and drive old pac to Brooklyn and head home.
Awesome, will be good to meet you! Although it is a morning start......And a Sunday...... The hangover posibility is high :P
Oh and guys, links to some hand held uhf things -
http://dicksmith.com...ndheld-cb-radio
http://dicksmith.com...ld-cb-radio-2pk
Haha yeah I think you will need a set I you wanna talk or listen... Not all cars need them but would be good to have one! I'll get one for sure :woot:
Would be an idea to call up a northbound truck once we hit the F3 and ask them how the run south is. Should let you know if any candy cars around
EDIT Fthose who don't know chanell 29 is used by the trucks so no being idiots on that chanell
Edited by m.j.h
For the F3 yeah but we will be on the speed limit the short time we are on it (20mins max) then its all twistys mate :thumbsup:
Hey Mat, count me in!
Will be sweet to meet all u guys. Ill meet at the coast spot, black r33 gtst :)
Good stuff mate, really glad your coming along! Best way to get into the scene haha... Come say g'day, I am useless with names but look for the white 34 with black wheels ;)
This will be an EPIC cruise... So many coming!
Oh and a big thanks to Mick_o in advance for the help with scouting the Galston point.... We didn't allow for this many cars so a few tweaks on the original plan at needed....
At this stage guy ferry is OUT! Too many cars and too many are low.... To save headaches we will go down the gorge and go for a break, then head back up!
We are considering footage of the run both on Galston and Old Pac, NO silly stuff just a nice compilation... This will require help from a few volunteers willing to run ahead etc.... If u have a cam and can help PM me, if not, we will wing it as I do best haha :woot:
camera, check, footage for compilation coming!!
Who is driving man? Reckon we can get you to run ahead at a few spots? I'll Gate u :P
Haha too easy, keen as. Can't wait too see ur 34 also man!
Good stuff mate :) happy to show u the 34... We have a mix of Newy and the Coast and a few others... Will be chilled, nice cars and a few twisties :) you'll enjoy your car too!
So I now have a spare seat for Sunday
Melisa is working Sat night and the original plan was for her to finish early and come on the cruise but she has decided that lunch with girlfriends is a better option
So can now help with photo duties etc if needed
Benji needed a lift :ph34r:
i got my hand helds from supercheap for $30 if that helps.i wont be taking one to much shit talking :whistling:
U trying to say something punk? :P haha
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
