He has also told me that it is a very low clearence build and for the run in he does not want me to rev it over 5k or come on boost hard for the 1st 1000km or so. So im gona take it farily eazy on the cruise, i might give it a bit of a squirt here and there but not gona open her up and eat someones children this time.
  • Replies 321
Posted Images
I'll plan to go flying past you in my slow GTT, just because you can't open the taps on this run. ;)
Set the boost limit as low as you can!
Lol smartass :P
hahah next run ill eat ur children feed them into my air intake hahahah :woot:
i dont have a boost controller, ill be running stock boost on it untill i do the turbos and ECU i think, dont want to damage the new block because of high boost on shit turbos.
man i dont even know what she is gona sound like, i had new Xforce dump pipes put on so it should have more power and sound alot better too, im f**king sooooo pumped up to get home from orange tomorrow and pick her up. We are going to stop in on the way back to the office from orange and pick her up since we drive past.
Good stuff! I drove the car with the boost controller switched off today, 16psi still :ph34r: lol
Christ, I don't even make that much boost with my controller on!
14psi on, 5psi off.
WHATUUUUP!
You should have left the stock dumps on Adam, Those hks style dumps can cause turbulence issues and hurt response
I will see how she goes, if i have issues ill just put the stock ones back on.
i think this will be the hardest thinkg i will ever do in my life...... :angry:
Just think of the $ it will cost to do again! So behave!! Lol
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
