Wanted:garrett 3076 Turbo To Suit Standard Manifold Asap
Just checking; you are buying an aftermarket headlight for your V35, and the new headlight comes with a daylight running light that you want to wire in? You have the option of just not wiring the DRL in, and the new headlight will work like the old. If you want the DRL to work you will have to wire it in on the car as it wasn't delivered with one. Best way is to add a Normally Closed or Changeover relay in the car, and wire: 87a to both DRL power wires 30 to a fused ignition power source 86 to earth 85 tap into the power wire that goes to the low beam headlight Note, you cannot use the much more common Normally Open relay for this, you need the DRL to turn off when the headlight is on and vice versa.
By Jayson20019 · Posted
Hi i do buy a aftermarket headlight on ebay. For v35 skyline coupe. I know that its a plug and play and just use the old low beam light and balast from old headlight. But my problem is i dnt have knowlage on car and electrical thing. And the head light getnon ebay is the wire for halo ring light is not connected. I talk to the seller and he said that. What white and black wire for halo robg light is need to connect to RDL. Running day light. Anyone here can tell me how to connect it to Rdl? Which wire is yhe RDL? -
By Neostead2000 · Posted
Hey Kaz, Unfortunately I am not at home currently and wont be for a few more months so I do not have access to my files or CAD. And at this point I prefer to keep the files to myself as I want to potentially make a few more pairs and see if they will sell within the EU before openly marketing them. But the way it's shaped and how small it is, I don't think you can fit both an indicator and a fog light onto the same surround, unless they were very small LED-type clusters. -
I’ve just installed a Uniclutch sport into my R32. I’ve been blown away by it… it drives like a stock Toyota Corolla. It doesn’t make sense to me that a performance clutch can drive this well. I was about to pull the trigger on a Nismo Coppermix twin plate when I discovered the Uniclutch and decided to give that a shot instead. They’ve changed the game and I couldn’t be happier. I was previously using an Extreme cushioned button clutch with lightened flywheel. I’m still using the same lightened flywheel with the Uniclutch.
