im selling my R33 remapped ecu with supporting mods made 210kw @12psi
mods are as follows:3 inch exhaust ,stock turbo,stock injectors,fmic,stock afm.
can send pics of dyno sheet if needed.great cheap upgrade to ur r33
$250
i can tell you.. toshis tunes are one of the best.. i will always get my stock ecu remaped throuogh him, so much beta then aftermarket ecu!, and safer..
exactly why the topic says "with supporting mods"
Did u read past the words "with supporting mods"? If u didn't, it clearly states stock turbo.
So back to my question.....
Edited by White_33
standard turbo can handle a max of 14psi but safely will handle 12psi.u can run 10psi with this ecu but u will probly only make 200kw.
sorry guys i stuffed up with the price toshi sells these for $650 plus cost me a tank of fuel so i want $350 for it.still very safe and cheap power upgrade for any r33 with suporting mods
I do not sell $650.
I charged to him $550 real time road tune for his car include chip and ecu modified.
Straight from the man himself. Offer in my pm is still there if you're still interested.
  • 2 years later...
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
