Update.
I picked up the car from Racepace today.
Since the first tune on this car back in October 2012 I have changed the exhaust system and now all the standard intake items have been re-installed.
So I asked them to do a re-tune and make it a bit more responsive (existing tune was a track safe tune so was a bit rich).
So we upped the boost from a previous 18/19psi to 19/20psi this time around and also played around with ignition timing etc.
The end result is AWESOME, the way the car drives now is SO much better. It is so much more responsive and so much easier to drive, less labored and more responsive.
The peak power numbers do it no justice, it is all in the torque and power delivery, so much better now.
Old Track Tune: 349.6 rwkw (4th gear)
New Street Tune: 353.4 rwkw (4th gear)
New Street Tune: 359.6 rwkw (5th gear)
Apparently the dyno was hitting some limiter in 4th gear?
Apparently that is why you see the sudden drop at the end of the power curve?
But the 5th gear run allows the run to rev right out?
Can someone explain this to me?
Here are the old and new 4th gear runs overlayed with POWER and TORQUE:
Here is the new 5th gear run with POWER and BOOST:
  • Like 1
Here is a photo of the factory BOV's installed.
I am running them as vent to atmosphere for the moment, just until I can source the right BOV return pipe.
Installed a filter just to keep the dust and water out.
Thanks Piggaz,
Good question.
At the end of the day I know there is more that can be done with the current set up, so I will continue to develop it until such point that no more can be done.
When I hit that stage I will then commit to a full rebuild with a forged bottom end.
Next round of mods for the current set up will be...
1) Remove 3" high flow cat and replace with Venom 3.5" in/out 5" body high flow cat
2) Remove Tomei cams and install standard cams
3) Install cam gears
4) Re-tune to suit above changes
I will probably do all this in November / December.
Just got back from Calder Park.
Not sure how I feel? But one thing is for sure, my driving skills are clearly getting worse as I get old.
Anyway, the three runs I did were...
RUN 1: 13.591 @ 119.89mph (2.712 60')
RUN 2: 12.965 @ 114.14mph (2.019 60')
RUN 3: 13.016 @ 116.17mph (2.265 60')
I think the expectations my old R32 GTR set were too high.
In my R32 GTR I ran a 11.573 @ 117.89 mph (1.712 60') with at least 60rwkw less than in my 34 GT-R.
But the 32 was running stock suspension (good squat) and stock 16" wheels with chunky Advan A048R's on the rear - must have made a big difference.
Oh well, it is what it is.
car was clean as last night, job very well done with it...looked a million dollars on the track :thumbsup:
I was a little bummed with the times the car was running, to me it felt like it had a lot more in it,
were you having some issues, or not pushing it hard?
-Ender
Thanks.
I am not sure what the issue was.
I think a combination of bad driving and maybe clutch?
But he mph was OK, so once I get my driving sorted and maybe a new clutch I should run maybe a high 11.
  • 2 years later...
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
