Well my N1 RB26 just died, not sure what exactly happened, but the outcome is a broken exhaust valve on cylinder 6, which has munched the piston and damaged the combustion chamber, upon stripping the engine, i have discovered that while the bore was unscathed of damage from the valve, the block is cracked.
500-600hp will do that i guess.
Now im still unsure of what path i want to proceed down with the engine build, do i get an already built one and then sell off parts from my old one, just buy a bare block, source a new JE piston and fix the head up, etc
So guys, show me what you have and then ill start making decisions on what i available, and what path to go down, $$$ of course are not something i want to throw away, so i want to do it right and once.
https://www.sau.com.au/forums/topic/411511-rb26-block-or-motor/
I guess that why the previous build was done with an N1 block, purely because they are stronger, didnt help me though
I should mention that i live in Mackay, Nth QLD
Give me a bell mate, I have a couple of motors for sale at the moment
Pete
0448468884
I too was thinking n1 block for my new build, but you must remember an older block has been through more heat cycles and making it stronger.. I've yet to decid either
Partial grout filled block.....sorted ;)
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
