i was playin with my air intake today, and discovered if the hose that comes off the back of the main intake pipe, above the tapet cover, firewall side, is blocked, the engine just dies without any throttle applied.
Now, i would surmise that this is the idle air feed, as the butterfly is completely closed when the throttle is right off, and with the car running at an idle, a hell of a lot of air is getting sucked into that hose.
I guess what im trying to say is see if the solenoid that this pipe goes into is buggered, maybe the pipe is blocked, or the throttle position sensor is faulty.
don't place too much faith in these diagnostics, they're just ideas of an amateur !
cheers
Phil
https://www.sau.com.au/forums/topic/41153-engine-dies-out/#findComment-844284
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
