Need Licensed Smash Repairer Consultation In Fairfield West!
Anyone who works for or owns a licensed smash repairer who can swing by my place in Fairfield West 2165 to give me a consultation on how to go about fixing it to industry standards? This is for my stat write off R34 with front end damage and I'm looking to have it repaired and reregoed. Any help would be highly appreciated :)
and NO, stat write offs CAN be re-registered and this has already been clarified by the RTA/RMS so this will not be a topic to debate.
Never mind. Just found out it cannot be done since it is within 15 years old. Kind of stupid actually how you can repair a car that is older rather than newer. People who make these laws and legislation have no common sense.
Wrecking time!
Wrecking time!
Couldnt just wait for it to become more than 15 years old?
Yeah I was thinking of leaving it till next year, but not gona bother fighting for it anymore. My insurance didn't give me any salvage rights and I had to auction it back and apparently after buying it back from a 3rd party, it's no longer eligible for a Repair Authorization.
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
