The rim size isn't the critical factor, rather the tyres you fit to the rims - if you fit an 18" tyre with the same outside diameter as your currrent 17", the ride height will be the same. To get the same OD you will need lower profile in the 18s - use a tyre calculator to work it out.
I thought the snow button made it take off in 2nd gear, to reduce wheel spin, but I might be worng - don't get much snow in Adelaide:)
https://www.sau.com.au/forums/topic/412169-18inch-rims/#findComment-6592023
bahahahhaha ! going for a new rims this weekends though . Only reason i ask cause of my drive way down to my garage, first time i bought my car home i got stuck and my car basically just hit the ground in the middle and start getting wheel spins :( .Now i sort out my decent with really side way entry down to my garage .
https://www.sau.com.au/forums/topic/412169-18inch-rims/#findComment-6593957
hahhahah if i do that i will rip my exhaust off ! will post 2 or 3 photos on newbies! loving my car every second of it .last couple of nights ,if i cant sleep i just go down to my garage and staring at it 4 couple of hours lol .
https://www.sau.com.au/forums/topic/412169-18inch-rims/#findComment-6595061
I was the same haha, i park out the back of my work and every now and then i'd walk around there and just look at it to make sure it's okay lol. I still get a little bit of a smile when i walk up to it after 9 or so months of owning it. Always getting compliments too, the females love it. My girlfriend hates it...
https://www.sau.com.au/forums/topic/412169-18inch-rims/#findComment-6595874
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
