Hi I have a Xbox 360 up for grabs comes with 9 games and controller and remote, very good condition never use so I need it gone, also have a Acer laptop which I don't need anymore,Acer Extensa 5630, Intel Core2 Duo,Windows Vista Basic, Wireless,Bluetooth connectivity, Excellent condition, Comes with charger
$250 Ono- xbox360
$300- Acer Laptop
hey mate dont jump all over me here as im just trying to help, but the newer version of the xbox is only 199 brand new. these tend to go for between 50 -90.
deal with a lot of xbox's (i repair them).
The newer version is no different to the first except for 32gb harddrive,it's not only the console but comes with few hundred $$ worth of games to mate so don't appreciate ur input.
By the way if that xbox has a 2006 sticker on it, it simply will not sell. The 2006 xbox's had a failure rate of over 98% in the first 2 years. Just a heads up.
$250 Ono- xbox360
$300- Acer Laptop
Yeah sorry dude that's way over priced. I picked up a brand new 360, 320gb with 4 games for $299
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
